Author Topic: FUSE KEEPS BLOWING  (Read 5235 times)
Offline 75 C20
FUSE KEEPS BLOWING
« on: May 05, 2006, 09:47:00 pm »
I have a 1975 C20. I recently got a License Plate Light from NAPA. i hooked it up to the existing wire and ran a ground to the tail light ground to the hitch wherer it is mounted. It is just held on to the license plate by 2 bolts and nuts. Heere is the light itself...
www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=LIT&PartNumber=26330&Description=License+Plate+Light
Its a 20 amp fuse that does it and the tail lamps etc... But ever since i put that light on I keep blowing the 20 amp fuse. I looked for shorts over and over and didnt find anything. Any ideas?? Do i need to stick a 25amp in there because it isn't a factory light and maybe it pulls a little more????  Any suggestion?
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
STG
« Reply #1 on: May 05, 2006, 09:19:00 pm »
Short to ground. You should just hook the wire to your marker lamp wires. The housing is grounded through the screws
Offline 75 C20
fuse
« Reply #2 on: May 06, 2006, 03:21:00 pm »
I figured it out. The fuse was 2 small i stuck a 25 in it and it seems to be working. I looked at the blown fuse and it was just metled and not blackened meaning that is wasn't a short but thanks for the adivce anyway
