73-87 Chevy & GMC Trucks
Leaking Edelbrock fuel filter. Dried out?
Topic: Leaking Edelbrock fuel filter. Dried out? (Read 6142 times)
SUX2BU99
June 18, 2006, 01:45:00 pm »
85 Chevy SWB FS 2wd mild 350. I haven't driven it in a month to 5 weeks or so. Not started the motor either. I fired it up yesterday and found that my 1-1.5 year old aluminum Edelbrock fuel filter with replaceable cartridge was dripping quite a bit of gas, right onto my valve cover over my headers
I took it off, took it apart, cleaned it out and put it back on the drip was still there. Did the rubber O-ring perhaps dry out in that month of non-use? Freaked me out since that is obviously a potential fire waiting to happen. It was leaking right where the 2 halves screw together and are sealed with an O-ring. It didn't LOOK warped or anything but who knows.
Thanks!
Re: Leaking Edelbrock fuel filter. Dried out?
June 19, 2006, 04:06:00 pm »
I hate those fuel filters. Just get a clear 3/8" fuel filter.
75 C20
June 20, 2006, 05:31:00 pm »
i don't think there bad- just try a new rubber o-ring
Edited by:
75 C20
at: 6/20/06 4:31 pm
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
SUX2BU99
June 20, 2006, 10:56:00 pm »
Any idea where I could find just the O ring? Would it be anything special? I ended up buying just a regular canister-type Fram filter for a whopping $4 and it did the trick. But I don't want to waste the $20 Edelbrock just because of a bad O ring.
75 C20
June 23, 2006, 02:51:00 pm »
just take the old o-ring out and go to ne napa or advnaced autos etc... and they should be able to get a o-ring- i dont think they are ne thing special...just a old standard oring
DnStClr
June 23, 2006, 04:53:00 pm »
Some o-rings will not work with fuel and solvents. If the're made of the wrong material they will swell up. And leak.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
