Author Topic: AC Blower not cutting it  (Read 5496 times)
Offline Zip7SC
« on: June 27, 2006, 10:29:00 am »
Own a 1986 GMC Sierra K1500.  Factory AC has been upgraded.  Freon is fully pressurized.   Air blows relatively cold, but barely comes out of dash-mounted vents (the floor vent works ok).   Is this a common problem?   Will upgrading the blower/fan provide a boost?   Is there a quick fix to this problem or should I have a professional diagnose?    Great forum.  Appreciate any and all feedback.   90+ degrees here in SC until Labor Day!    Thanks.
Offline roundedline
Re: AC Blower not cutting it
« Reply #1 on: June 27, 2006, 10:02:00 am »
Sounds like your flaps may be closed if it is blowing down to the floor harder than above.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Zip7SC
« Reply #2 on: June 27, 2006, 12:24:00 pm »
Roundedline,
Thanks for the reply.  Now to followup a dumb question with an even dumber one.....is there a single flap that inhibits (and allows airflow) to all the vents, and where would that be?   I'd look rather than bothering you, but I'm at work and the truck is home.     I appreciate all you add to this site.   I find it very helpful.
Thanks.
« Reply #3 on: June 27, 2006, 09:30:00 pm »
Check the vacuum hoses at your reserve cannister in the engine compartment.
