Author Topic: Help... Centering the steering wheel in these trucks  (Read 5273 times)
Offline autonuerotic
« on: June 19, 2006, 03:58:00 am »
My truck sits too low to take to an alignment shop, nobody will do an alignment.  I roughed my alignment (no funny tire wear yet) and I need to center my steering wheel, because its driving me nuts!  Anybody know how to do this?  I already made an attempt trying to do it by adjusting the rag-joint. It didnt work because the splines are referenced to go on only one way.  Help???:rolleyes
Offline roundedline
Re: Help... Centering the steering wheel in these trucks
« Reply #1 on: June 19, 2006, 02:19:00 pm »
You have to put the steering wheel where you want it to be first and then align the frontend.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
« Reply #2 on: June 19, 2006, 04:04:00 pm »
Lock the steering wheel straight ahead and measure the distance at the leading edge of the front tires and then the trailing edge of the front tires directly at the centerline. Adjust the tie rod linkages to be equal and you will have zero toe. Alternative: If your truck is too low find an alignment shop that has a pit.
« Reply #3 on: June 20, 2006, 03:18:00 am »
Awesome... Thanks guys, Ill fix it this weekend!
Offline RSBAD454
« Reply #4 on: June 27, 2006, 10:57:00 pm »
I took mine to a shop that has a pit and a rack....of course mine needed the pit as well.
Toys are my game
http://
Offline got2haul
« Reply #5 on: October 06, 2009, 02:57:00 pm »
Found this old thread regarding centering the steering wheel.  The GM shop manual says that the steering box (in my case, a 1980 power steering unit) must be centered or high centered (I don't remember the exact terminology used) prior to adjusting the tie rod ends to center the steering wheel.  The manual doesn't go into detail about how to do this.  Anyone know?
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
« Reply #6 on: October 06, 2009, 03:51:47 pm »
Turn the wheel where it is straight , lock it in place (most use some form of a tension tool) and then adjust the tierods accordingly.
