Author Topic: 87' Custom deluxe 4X4 mode  (Read 10406 times)
Offline berkbs
« on: July 08, 2006, 08:54:00 am »
Hi
I am writing this message from a country far away where people know almost nothing about Chevrolet pickup trucks so bear with me.
How do you put an 87' custom deluxe pickup truck in 4X4? Now it's only rear wheel drive. The truck has auto transmission if it makes a difference.
I borrowed this from a friend for few days but now can't reach him therefore I am asking here.
Thanks in advance,
Berk
Offline roundedline
Re: 87' Custom deluxe 4X4 mode
« Reply #1 on: July 08, 2006, 09:51:00 am »
First, Is it actually a 4x4?
How to tell, there will be a shifter on the floor labeled 2H - 4H - N - 4L?
If it is there, then you should have locking hubs also.  If you want it in 4WD, you need to move the selector to 4H and then lock the hubs.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline RSBAD454
« Reply #2 on: July 08, 2006, 10:03:00 am »
Hubs will automatically lock if it's an 87 I believe...
Toys are my game
http://
Offline berkbs
« Reply #3 on: July 08, 2006, 10:44:00 am »
What should I set the gear before moving the lever on the floor? Does it matter?
And what do you mean by hubs? My vocabulary is suffering a little here. Are they on the front wheels?
Thank you for the help
Berk
Offline RSBAD454
« Reply #4 on: July 08, 2006, 11:53:00 am »
Yes, the hubs are on the front wheels.....they are either manual or auto locking. Auto hubs have a smooth front face. I think you should leave tranny in park or nuetral to move transfercase selector.
Manual
Toys are my game
Edited by: RSBAD454  at: 7/8/06 10:54 am
http://
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #5 on: July 08, 2006, 07:27:00 pm »
YOu can go under 25 mph and then slide the lever from 2h to 4h, all in one motion.   At least, that is how my 91 works.  YOu can go any speed when going from 4h to 2h.  Just unlock the hubs afterward (back up 10 feet when you get a chance).
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel  at: 7/10/06 10:48 pm
Offline DnStClr
« Reply #6 on: July 08, 2006, 06:55:00 pm »
By the way, Berks, welcome! Where do you live?
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Offline RSBAD454
« Reply #7 on: July 08, 2006, 06:55:00 pm »
I tried that in a 1981 4x4 I drive for work and it won't come out of 2H. Maybe it's just old...who knows.
Toys are my game
http://
Offline berkbs
« Reply #8 on: July 09, 2006, 08:43:00 am »
Hi
Turkey in summers, Sweden in winters. Originally from Turkey.
Thanks for the replies. I did not get around to trying to put the truck in 4X4 yet, I will post the result here. I don't think there will be any problems, directions I got here was simpler than I thought.
Regards, Berk
Offline 1976Scottsdale
« Reply #9 on: July 09, 2006, 12:09:00 pm »
Nothing to it.  Only thing to remember is to shift the transmission into neutral (N) before shifting the transfer case through Neutral(going from 4 lo to 2 hi or anything)
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #10 on: July 09, 2006, 01:25:00 pm »
Right, like 1976scottsdale says, going beyond N requires the trans to be in N and vehicle stopped.  Don't go over 40 mph in low though.
Just make sure you don't play around with shifting the lever---Throw that joker into place or you will get ginding.  Going back from Low to high will require a slight pause in Neutral of the drive selector.
Dont forget to unlock the hubs after going back to two wheel drive.  If it is automatic hubs, you must put your trans in reverse after the switch.  Back up about 10 feet to automaticallly release the hubs. Manually, well, you gotta do it manually.
SgtDel
aka "Andy"
www.delbridge.net
Edited by: SgtDel  at: 7/10/06 10:47 pm
