Author Topic: Bed Bolts  (Read 7560 times)
Bed Bolts
« on: August 18, 2006, 06:32:00 pm »
Does anyone know the exact dimensions for the bed bolts? 8' Fleetside.
Offline roundedline
Re: Bed Bolts
« Reply #1 on: August 19, 2006, 03:34:00 pm »
As in diameter and length?  This is for the 8 holding it down right?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Re: Bed Bolts
« Reply #2 on: August 19, 2006, 03:45:00 pm »
Yeah I know they are 1/2" carriage bolts and one is long...
Offline roundedline
Re: Bed Bolts
« Reply #3 on: August 21, 2006, 08:04:00 pm »
Anyone?
« Reply #4 on: August 25, 2006, 04:52:00 pm »
bump
Offline 123 pugsy
Re: Anyone?
« Reply #5 on: August 26, 2006, 07:36:00 am »
Bolts are 4-1/4".  Long ones should be 6-3/4" longer (frame thickness) giving you 11".
Hope this helps.
Pugsy
Pugsy
76 C10 LWB
TPI 350
Re: Anyone?
« Reply #6 on: August 26, 2006, 08:06:00 am »
Thanks Pugsy! I forget, how many long ones are there? Just two? I ripped the bed off this thing 3 years ago and torched the bolts so I can't remember!
Offline 123 pugsy
Re: Anyone?
« Reply #7 on: August 26, 2006, 10:30:00 am »
Should be 2 and 6 I believe.I've got 6 shorties on mine due to the fact I have a newer box on an older frame.
Pugsy
76 C10 LWB
TPI 350
Offline roundedline
Re: Anyone?
« Reply #8 on: August 27, 2006, 11:20:00 pm »
Should be one long one.  Typically it is on the drivers side away from the fuel lines.  I have seen them with long ones on both sides though.
Project Su
Jimmy 2WD Project
