Author Topic: Poor Fuel Economy  (Read 5284 times)
Offline mjolinar
Poor Fuel Economy
« on: September 05, 2006, 12:13:00 am »
I have a 78' 4x4 SWB 1/2 ton with a Small block 350 and TH350/NP203 converted to part time, with 3.73 gears in the axles. Carburation is a Holly 670 truck avenger. I get about 8 mpg on the freeway and think it should get much better than that.
I have seen the exact same truck with a 4 speed and NP205 get 17-18 mpg on the freeway.
Any suggestions or ideas?
Re: Poor Fuel Economy
« Reply #1 on: September 05, 2006, 05:31:00 am »
Tune up, fuel / air filters, timming adjustments, carb adjustments?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: September 05, 2006, 12:11:00 pm »
If all you do is freeway driving and no hauling/towing, then get rid of the 3.73 and throw in a 3.08 or higher rear.
My 79 Big 10 with th350/383 stroker engine gets about 13 city, or higher, 16 mpg on the interstate.  I have a 3.08 and she will get up and fly on the interstate.  It has a new qjet and I don't open up all four often.
SgtDel
Re: > Re: Poor Fuel Economy
« Reply #3 on: September 05, 2006, 09:44:00 pm »
Meter down that carb first of all. 8MPG if properly tuned is pretty bad. Leave the 3.73:1 and swap in a 700R4/np208 drivetrain.
Offline mjolinar
« Reply #4 on: September 18, 2006, 11:38:00 pm »
Changed the jets. Seems to have improved it quite a bit. Going to mess with timing adjustments next.
