Author Topic: 86 Suburban 454, High beams not working, Help please!  (Read 4949 times)
Offline Foxracing500r
« on: November 26, 2006, 10:45:00 pm »
Ok a lil background, I have a 86 Suburban 454.
The High beam switch is on the columm and when I pull it towards me, the Low beam lights die, along with any other light.
The lever doesnt lock like the high beams would be on, it just springs back.
I am stuck, I looked in my Haynes and found nothing, can anyone help me please?
Offline toplessblazer
Re: 86 Suburban 454, High beams not working, Help please!
« Reply #1 on: November 26, 2006, 11:31:00 pm »
Do you have a tilt steering column? Is the tilt column loose like you can move the steering wheel up and down and side to side. I have had loose columns not let me operate the high beam switch. If the column is loose there is a fix it article in the tech section. Could be you just need a new switch that mounts on the column down under the dash.
« Reply #2 on: November 27, 2006, 08:24:00 am »
Nah the collum is tight, Any tuts on how to replace this switch? and how much $ ?
