Author Topic: V.I.N. decoding  (Read 7818 times)
Offline clayton400
V.I.N. decoding
« on: December 03, 2006, 10:18:00 pm »
Is there anyway to tell if a truck came from the factory as a Silverado, Scottsdale or Custom deluxe?
Offline roundedline
Re: V.I.N. decoding
« Reply #1 on: December 03, 2006, 09:51:00 pm »
Not from the VIN.  If the RPO codes are still in the glovebox that would be the only way to confirm it.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline xtreme80
Re: V.I.N. decoding
« Reply #2 on: December 04, 2006, 11:02:00 am »
If you do have those RPO codes, you can look that info up here...
www.73-87.com/7387info/7387trimlev.htm
Offline clayton400
Re: V.I.N. decoding
« Reply #3 on: December 04, 2006, 09:07:00 pm »
Thanks guys
Offline Prong
Re: V.I.N. decoding
« Reply #4 on: April 22, 2007, 06:59:04 pm »
Found this while snooping around, it may help...
http://4x4.straydogs.ca/gmrpo.html
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline mike357
Re: V.I.N. decoding
« Reply #5 on: April 22, 2007, 09:37:58 pm »
is there another way of telling what ratio the truck has? i would like to figure it out without taking the cover off and counting teeth.
Offline red4wd
Re: V.I.N. decoding
« Reply #6 on: April 22, 2007, 09:48:09 pm »
look at the 3 letter codes on the white sticker in the glove box...GU4=3.08, GU6=3.42, GT4=3.73, GT5=4.10.  That is assuming that the factory rear end is still in the truck.
Offline mike357
Re: V.I.N. decoding
« Reply #7 on: April 24, 2007, 12:29:18 pm »
well thats the problem all the RPO's in glove box are labeled with what they actually are and none of them mention anything about gearing.
Re: V.I.N. decoding
« Reply #8 on: April 25, 2007, 09:34:17 am »
If it isn't listed, it will be a 3.08 for 12bolt and 2.73 for 10bolts.  This is assuming it has never been replaced.
