Author Topic: How much would you pay?  (Read 10263 times)
Offline 77GMCSerria
« on: January 06, 2007, 10:33:00 pm »
How much would you pay for a 1983 Chevy K30 4x4, Auto, 350, Crew Cab, Dually, Power Windows, Power Locks, A/C (would need to be recharged or connected) and has a plow frame?
The motor(not original) needs a rebuild, the tranny and t-case have been rebuilt.
The frame looks like it has been painted in the past but could panted agian but not that bad.
The cab needs cab corners, rockers and 2 rear doors, the floors are solid.
The truck originaly had a dump body on it, but it dosen't have any PTO stuff on it. It is a project truck. At the moment the truck radiator support and grill needs to be put back on.
The truck doasen't run and drive!
Edited by: 77GMCSerria at: 1/6/07 10:43 pm
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: How much would you pay?
« Reply #1 on: January 06, 2007, 10:37:00 pm »
If the dually part an 4x4 and crew cab parts are important to you, you could pay up to $3k if it needs that much work.
If those items are not that important to you, you have so many more trucks to chose from, I'd say under $1500.  As I have said many times, depends on where you are too, a Mississippi dollar and a NY dollar are completely different.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Offline 77GMCSerria
« Reply #2 on: January 07, 2007, 12:46:00 pm »
The truck is actually a 1981.
He wants 1k for the truck.
Online Mr Diesel
  • Aaron
How much
« Reply #3 on: January 07, 2007, 05:09:00 pm »
If you don't buy it, would you let me know where it is? I would pay 1k for that truck if it was fairly close...
- Mr Diesel
'76 C30 Crew 6.2
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline 77GMCSerria
Re: How much
« Reply #4 on: January 09, 2007, 09:31:00 am »
If I was to buy this truck I was thinking about putting a Fuel Ijected Motor in it. I know that Painless has kits for chevy FI from TBI to Vortec. What do you think would FI be a good idea?
Offline roundedline
Re: How much
« Reply #5 on: January 09, 2007, 12:35:00 pm »
I personally think EFI of any type is a good idea, but I HATE carbs...
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Edited by: roundedline at: 1/9/07 12:35 pm
Offline 77GMCSerria
Re: How much
« Reply #6 on: January 09, 2007, 12:27:00 pm »
The reason that I am looking at EFI is that I want better fuel economy and in the winter it would be easiser to start. Is there anything else that EFI will do on a positinve note? Which verison of EFI is the best? (TBI,TPI,LS1,LT1 or Vortec)
Offline roundedline
Re: How much
« Reply #7 on: January 10, 2007, 01:04:00 pm »
Drivability, automatic compensation for different environments/climates, longer engine life,
If I had a choice, I would select the new Vortec motors.  I have one in the progress stage right now....
p210.ezboard.com/f7387che...2395.topic
Project Su
Jimmy 2WD Project
Offline 77GMCSerria
How much
« Reply #8 on: January 10, 2007, 07:30:00 pm »
Do you need any adapters to the mounting of the vortec motor in to a 4x4 1981 p/u? If so where would I obtain them?
Edited by: 77GMCSerria at: 1/11/07 10:39 am
Offline roundedline
Re: How much
« Reply #9 on: January 11, 2007, 05:50:00 pm »
Did you check my build up link?
Street And Performance is where you need to get them from or Advanced Adapters.
Page 15 of this link:hotrodlane.cc/onlinecatal...4-91ls.pdf
Or this page:
eshop.advanceadapters.com...ct_id=2544
Project Su
Jimmy 2WD Project
Offline 77GMCSerria
Re: How much
« Reply #10 on: January 11, 2007, 08:58:00 pm »
Thanks Roundedline.
Now for another question, simply put the a crew cab with an 8ft bed is too long, I would like to put a 6ft on but was woundering how much it would cost to have the frame shortened?
Offline roundedline
Re: How much
« Reply #11 on: January 12, 2007, 01:02:00 pm »
Read this:
www.73-87chevytrucks.com/lwb_to_swb.htm
If you mount a short bed on there you can tell where it needs to be shortened....
Project Su
Jimmy 2WD Project
Offline 77GMCSerria
LT1?
« Reply #12 on: January 23, 2007, 09:28:00 pm »
Can I use the stock motor mounts on the 81 Crew cab to put in an '99 LT1 motor? If not are there any adapters that I can use?
Edited by: 77GMCSerria at: 1/23/07 9:33 pm
Offline DixieOffroad87
motor mounts
« Reply #13 on: January 24, 2007, 02:55:00 pm »
first off street and performance mounts are weak in my opinion. go to brphotrods.com contact him the guys name is phil brewer he sells adapter plates that will work to put the 99 LT1 into your truck. and they are made of steel instead of aluminum like s&p. if you want any more info about them contact him. or you can ask me i used to work for him.
