Author Topic: steering colmn  (Read 3907 times)
Offline 73customC10
steering colmn
« on: February 12, 2007, 09:55:00 am »
hey i converted my automatic colmn shift to auto floor shift. do i have a nuetral safty switch?? or what do i do with the colmn. can i convert it from a manuel steering colmn or what???? thanks
Re: steering colmn
« Reply #1 on: February 12, 2007, 05:12:00 pm »
Yes you have a neutral safety switch. You can just take the lever off of the column or replace it with a M/T column
Offline Fast68
Re: steering colmn
« Reply #2 on: March 15, 2007, 03:48:00 am »
4 speed columns are very common in most regions still, not here, but should be where you are,
the manual trans trucks use a clutch start switch and the autos use the safety neutral switch
the clutch switch is a bigger white plastic slider one
i can pic one i have laying around if you need
good luck
