Author Topic: blower motor??  (Read 5352 times)
Offline 73customC10
blower motor??
« on: January 31, 2007, 07:32:00 pm »
my blower motor stays on low and wont turn off. it also wont go higher.?? how do i turn it off. thanks
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: blower motor??
« Reply #1 on: January 31, 2007, 08:04:00 pm »
'taint gonna turn off all the way.  To keep the pressure inside the cab from getting too high, the blower motor is designed to always be on.
As far as not being able to adjust the speed of the motor, your switch may be bad.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Re: blower motor??
« Reply #2 on: January 31, 2007, 09:15:00 pm »
Is the truck AC equipped? Check the Rheostat.
The blower fan circuit is designed to run on low speed to prevent mold from growing in the heater box. Any time the key is on the motor is on.
Offline 73customC10
Re: blower motor??
« Reply #3 on: February 01, 2007, 08:55:00 am »
it had ac but i took it out. but thanks i get what you guys are talkin about
Offline Fast68
Re: blower motor??
« Reply #4 on: March 15, 2007, 03:42:00 am »
they dont shut off completely if its not factory a/c delete
there is no off position with a/c panel fan switch
good luck
Offline 75 C20
Re: blower motor??
« Reply #5 on: March 15, 2007, 04:12:00 pm »
i put a switch on mine so i can turn my blower off- will that hurt ne thing- it gets annoying with it always blowing:\
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
