Author Topic: Fuse Panel Diagram  (Read 93879 times)
Offline zach791
Fuse Panel Diagram
« on: March 20, 2007, 08:52:00 pm »
Does anyone have the diagram or a picture of their fuse cluster. and the wires running to it... my little brother decided to help me out and unpluged everything from the inside of the cab fuse panel and there are some wires that plug into it and i dont remember their placement exactly. It is on a 1983 chevy k10 with a/c and power windows and locks
Offline roundedline
Re: Fuse Panel Diagram
« Reply #1 on: March 21, 2007, 02:02:00 pm »
Have you checked AutoZone for a Haynes Manual.  There are complete wiring schematics in them.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline zach791
« Reply #2 on: March 21, 2007, 07:13:00 pm »
Yea i have a Chilton repair manuel for it but it does not show fuse placement. I just thought if the right person seen this post it would save me a little time.
Offline Tire Burner
« Reply #3 on: March 22, 2007, 07:54:00 am »
There's this site: brochures.slosh.com/index.shtml?1986
It's not a Mainstream thing, but the Diagrams are Accurate. You might even want to print out yours for future wiring problems.
« Reply #4 on: March 23, 2007, 02:22:00 pm »
I just posted this in another thread
*edited out failbucket image
« Last Edit: February 23, 2019, 08:58:12 am by VileZambonie »
Offline MrBowtie95
« Reply #5 on: October 11, 2011, 06:21:55 pm »
which of these can be used for a constant 12V power supply, other than the battery
« Reply #6 on: October 11, 2011, 07:40:32 pm »
BAT
Offline MrBowtie95
« Reply #7 on: October 11, 2011, 07:48:45 pm »
are their any other locations other than the BAT. It's going to be for a stereo and I need something that won't stay on all the time.
« Reply #8 on: October 11, 2011, 07:51:24 pm »
You just said constant 12V power
Offline MrBowtie95
« Reply #9 on: October 12, 2011, 06:18:25 am »
Somebody told me there was a cigarette lighter block that was always hot until you cut the key off
« Reply #10 on: October 12, 2011, 08:48:31 am »
then its not “always” hot its a key or switch hot. but most of them are that, constant they are usually stop/hazard lights
« Last Edit: October 12, 2011, 09:14:18 am by Irish_Alley »
« Reply #11 on: October 12, 2011, 06:25:37 pm »
Constant means hot at all times. If you want a switched source use IGN
Offline slammed79
  • Thou shalt not drive stock
« Reply #12 on: October 19, 2011, 06:27:45 am »
You'll use a constant hot and ignition hot for a stereo install. The constant will keep your clock and settings from deleting every time you turn the key off.
Praise the lowered
« Reply #13 on: October 19, 2011, 04:25:28 pm »
Just a follow-up to this post that got pulled back up from 2007, All of the Wiring diagrams are available in the Tech section of the forum.
