Author Topic: won't start  (Read 5965 times)
Offline 74BBC
won't start
« on: April 08, 2007, 09:36:00 am »
Hey, I'm new to this site. My truck just clicks, I've replaced the starter, checked the ground wires, and checked the battery and starter and altenater with a voltmeter. The ignition switch is good also. Any help. Thanks
« Reply #1 on: April 08, 2007, 10:09:00 am »
How did you check the battery? Just because it has 12 volts doesn't mean it can provide 250 Amps of current to crank your engine. Try to jump start it with another vehicle. It's probably the battery but if you are positive the battery is good and had it load tested then try to rotate the crankshaft and make sure the engine turns.
Offline 74BBC
Re: ?
« Reply #2 on: April 08, 2007, 10:13:00 am »
tried to jump, still just clicks. I also tried to jump the starter, the engine turns a few times, could it be I need a high torque starter? It is doing this since I put in a new tranny 454/th400. Thanks
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: ?
« Reply #3 on: April 08, 2007, 11:11:00 am »
If you don't have a really nice set of jumper cables, it will do what you are saying.  I use really heavy duty thick jumper cables.
Do you have a battery charger?  You say you jumped it on your starter....wasa it directly on the positive bolt on solenoid?  Still, if you have a so-so set of jumpers, aint gonna do well.
You say it will turn over slowly....well, that is a start...it aint the tranny pump or it will just go clunk one time and freeze up.
Do what vile said....get a socket set and turn the crank over with the 5/8" socket manually a few times to see of free it is.
You should not need a high torque starter just because you changed transmissions.
I believe it is still your battery.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Edited by: SgtDel  at: 4/8/07 1:01 pm
Offline 74BBC
Re: ?
« Reply #4 on: April 08, 2007, 12:32:00 pm »
I turned the engine it is not locked up, I also ordered a high torque starter and will get a new battery tommorrow. Thanks again, I will let you know how it works.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: ?
« Reply #5 on: April 08, 2007, 02:01:00 pm »
I'd do one at a time....like start w/ the battery.
SgtDel
aka "Andy"
www.delbridge.net
« Reply #6 on: April 08, 2007, 02:07:00 pm »
If you are using a sb starter it surely will not work on your bb. Make sure you are using the correct starter for the 454.
Offline 74BBC
Re: 454
« Reply #7 on: April 08, 2007, 04:19:00 pm »
Hey thanks guys, It was the battery was weak and a ground wire was burnt into on the firewall. Runs like a champ. You guys are awesome.
Edited by: 74BBC at: 4/8/07 3:20 pm
