Author Topic: Emissions removal?  (Read 8047 times)
Offline yttaf
Emissions removal?
« on: April 27, 2007, 06:36:21 pm »
Well I have a 81 Chevy 1/2 ton with a 350 from a 79 corvette. I just bought a new Edelbrock aluminum intake manifold & I was wanting to get rid of the emission stuff.... egr, cat, evap canister, etc. as my new intake doesn't have the egr hole. Is there anything in particular I need to do in order to remove all this unwanted stuff? Will I be able to keep the A/C? If not no big deal as it doesn't work anyways. Any help would be appreciated.
« Last Edit: June 05, 2007, 09:20:17 pm by yttaf »
Offline cjtimp
Re: Emissions removal?
« Reply #1 on: April 27, 2007, 07:04:10 pm »
Be sure to check local laws concerning these parts before removing them....Here in TX you must keep original emission components for a certain length of time. (25 years here).... ???....
« Reply #2 on: April 27, 2007, 07:50:27 pm »
Leave your canister if possible, leave your AC definitely! If you have emissions testing you better leave the cat.
Offline alex83chevy
« Reply #3 on: April 29, 2007, 07:44:57 pm »
Just rip all the junk off and plug the holes. ;)
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
« Reply #4 on: April 30, 2007, 06:22:51 pm »
EGR actually extends the life of the motor thanks to the cooling of the cylinders that the system allows. The only time EGR would supposedly be restrictive is at wide open throttle, but that is when the valve closes, so it is a well designed system. In all reality, spending the extra 10 bucks for the manifold with the EGR port could be saving you thousands down the road when it comes time to rebuild that motor thanks to worn out cylinder walls. Just some food for thought.
Offline yttaf
« Reply #5 on: June 05, 2007, 09:16:31 pm »
Ok thanx for the tips guys!!! So I need to keep the canister in order to keep the a/c?
« Reply #6 on: June 05, 2007, 09:21:08 pm »
A/C and canister are unrelated.  I would keep the A/C (and I am sure this is what Vile was getting at) because it is HOT!
Offline yttaf
« Reply #7 on: June 05, 2007, 10:40:43 pm »
ok then... canister will be going bye bye...
& yes it would be nice to have a/c since it can get pretty hot here in Iowa
Offline 123 pugsy
« Reply #8 on: June 06, 2007, 04:55:25 am »
If you toast the cannister ,where will you vent your gas tank to? You can leave your vent hose to the cannister,but remove the other lines going to it.
Pugsy
76 C10 LWB
TPI 350
« Reply #9 on: June 06, 2007, 08:43:28 am »
I agree, keep the canister.
Offline yttaf
« Reply #10 on: June 06, 2007, 03:04:25 pm »
Ok I'll keep the canister, I'll just remove the other lines that won't be used then.
Thanx!!!
