Author Topic: Doors  (Read 5479 times)
Offline oldandrusty
Doors
« on: April 30, 2007, 10:11:45 pm »
Well I am sure that this has been talked about before but i have a 78 truck and wanted to know if the newer doors like off a 85 or something would fit on mine?
Thanks
Offline shaved80
Re: Doors
« Reply #1 on: April 30, 2007, 11:36:39 pm »
yes. but there is something different about the inner door that is different. mounting holes for the window motor or something? someone else can chime in with that.
Offline 123 pugsy
Re: Doors
« Reply #2 on: May 01, 2007, 06:08:53 am »
73-76 are different.  Door panels and window cranks are different on these years. The rest are the same.
Pugsy
76 C10 LWB
TPI 350
Offline joesgarage71
  • Wrench
Re: Doors
« Reply #3 on: May 01, 2007, 08:24:14 am »
Not sure what the years are I think 73-76 have the larger wing window, 77-87 have a smaller wing(larger rubber molding)
 Steve
« Last Edit: May 01, 2007, 08:26:17 am by joesgarage71 »
Offline oldandrusty
Re: Doors
« Reply #4 on: May 01, 2007, 04:40:00 pm »
Thanks for the info i just wanted to make sure if i bought these doors off this 85 that they would fit my 78 so thanks
Re: Doors
« Reply #5 on: May 03, 2007, 11:59:50 am »
Any 73-87 (RV to 91) doors will swap to any cab.  Where you run into trouble is when you try to put 77-91 pieces in a 73-80 door.  Mixing parts is not a good idea unless you stay within the normal 73-76 and 77-91 split.  The vents will still work regardless of size they are just have one less mounting screw.
