Author Topic: wireing  (Read 5340 times)
Offline jnmac
wireing
« on: May 07, 2007, 08:48:42 pm »
ok guys im kinda in a bind i think i have a 84 cab with a 84 wireing. but under the hood its 79. will this work? and if so what do i have to do to get the lights to work right? seeing that im gong from a two head light to four . well thanks alot
Re: wireing
« Reply #1 on: May 07, 2007, 08:59:11 pm »
Just use the wiring harness from the 84
Offline jnmac
Re: wireing
« Reply #2 on: May 08, 2007, 07:39:35 pm »
well see im trying not to because two reasons one its cut up pretty good and the 79 one is still clean and uncut and on the motor. granted i could use the one from the 79 to fix the 84 but it seem like it would be better/ eazyer to use the 79
Offline DrPepper1010
Re: wireing
« Reply #3 on: May 09, 2007, 06:52:33 pm »
I went from 2 to 4 headlights on my 82. All I did was cut the 2 pin high beam headlight connector and about 12 inches of wire from a donor truck. One wire is green (the hot wire) and one is black (ground). Then splice this socket into your 2 beam (low and high) headlight wiring. That's all that is to it. Mine works fine.
Good Luck
Offline jnmac
Re: wireing
« Reply #4 on: May 09, 2007, 08:58:53 pm »
thanks alot that helps
