Author Topic: help with spindle removal... and new a-arm bushings  (Read 5408 times)
Offline mikeith
« on: May 07, 2007, 09:35:35 pm »
ok i've down all the hard work but how do i get the spindles and the ball joints apart....  i've tried prying and tapping, and beating... i have the castle nuts backed to the end of the ball joint bolt but i cat get the spindle to come loose on either side...
and after i do that what do i do step by step to replace the control arm bushings, upper and lower
Offline joesgarage71
  • Wrench
Re: help with spindle removal... and new a-arm bushings
« Reply #1 on: May 08, 2007, 06:09:53 am »
 You need a pickle fork, I have gotten them loose by just using a big phord tool(hammer) and smakin' the side of the spindle where the ball joint goes up through. Keep the nut on there because of the tension of the springs (if your doing the lower ball joint) the uppers I use the fork.
 Steve
« Reply #2 on: May 08, 2007, 02:42:54 pm »
Give it shock treatment. Strike the knuckle where the ball stud goes through at the top and bottom with a 3lb sledge and it will pop right apart. Usually when I swing a hammer I picture my ex's face so I give it quite the impact! :o
Offline mikeith
« Reply #3 on: May 09, 2007, 08:53:06 am »
WOW the bushings are a pain w/o an impacy hammer!!!! got the new ones in though finally!! new spindles should be here today, the off to get her aligned!
