Author Topic: Help w/ 79 Scottsdale  (Read 6029 times)
Offline lt1kicker
« on: May 16, 2007, 04:23:20 pm »
Just picked up a 79 Scottdale 4x4 last night.  Runs good for an old truck, but has some issues that need corrected before I put it on the road.  The carb needs rebuilt, an old Quadrajet on the 350.  Should I replace it or get someone to rebuild it?
The lights dim and brighten w/ engine speed.  Is this a sign of alternator or voltage regulator failure?
Lots of oil leaking from the valve covers.  Should I R&R the intake gasket when I replace those as well?
Aj
1979 Chevrolet Scottdale 4x4, 350, 180k
1994 Caprice 9C1, LT1, G80
1995 Caprice 9C1, LT1, FOM9C1
www.fallenofficermemorial9c1.org
Re: Help w/ 79 Scottsdale
« Reply #1 on: May 16, 2007, 10:14:10 pm »
Q-jets are pretty easy to rebuild, but you can buy a reman from most major parts stores.
lights sound like a bad alternator.
I would just replace the valve cover gaskets.
Offline lt1kicker
« Reply #2 on: May 17, 2007, 07:33:37 am »
$294.30 for a rebuilt Q-jet from Advance.  I think I can actually save some $$ by going with a Holley.  Is that a good idea?
Aj
« Reply #3 on: May 17, 2007, 07:43:18 am »
I would take a well tuned Q jet over a Holley any day. Better milage as long as you keep you foot out of the secondaries and in my opinion more reliable. I will say I have had excellent luck with the Holley 500 that I rebuilt four years ago on my 55. But have had bad luck other Holley's over the years, and have always been happy with my Q jets.
Offline lt1kicker
« Reply #4 on: May 17, 2007, 10:49:18 am »
Well, I think I'll probably have my Q-Jet rebuilt.  Not a problem.  Just have to find someone to do it.  A lot of people say it's a PITA.
Aj
« Reply #5 on: May 17, 2007, 05:23:53 pm »
I have to agree with Blazin.  I wouldn't put a Holley on anything that I wanted reliability out of.  If it was a race car that I was always working on, sure.
I never really had problems rebuilding one.  I picked up a q-jet from Autozone for about $250 a last year.
« Reply #6 on: May 17, 2007, 08:14:32 pm »
It's not a PITA it's easy. I can do it with my eyes closed practically. Your rebuild kit comes with a part explosion. If you've never done it before just lay everything out carefully and orderly or spend $250 at autozone and get a reman
Offline lt1kicker
« Reply #7 on: May 17, 2007, 08:39:02 pm »
I think I'll rebuild it.  It's not running very bad at all, so that's probably all it needs.
Aj
