Author Topic: lower ball joints  (Read 6010 times)
Offline 75 C20
lower ball joints
« on: May 21, 2007, 06:04:55 pm »
im putting new ball joints, tie rod ends, idler arm and pitman arm on my 79 i bought and i was wondering if there is  any good way to press them in with out getting a press- i managed to hammer the old ones out and was thinkin maybe if i rig something up to pulll them in using the threads on them and a piece of pipe and a nut to pull it up or putting a floor jack under it an raise up on it????
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: lower ball joints
« Reply #1 on: May 21, 2007, 10:30:47 pm »
Just use a ball joint press. you can rent one for free from autozone.
Offline Stewart G Griffin
« Reply #2 on: June 14, 2007, 12:15:26 pm »
Ditto.
You can also get one cheap at Harbour freight for about $39.
See Sgt Del's excellent instruction post in the technical section concerning ball joint replacement.
Offline 75 C20
« Reply #3 on: June 14, 2007, 08:40:11 pm »
i finished that project awhile back
i did read sgt dells thing- it was very heplful
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #4 on: June 20, 2007, 08:39:39 am »
Glad I could help  ;D
