Author Topic: Speedometer  (Read 6055 times)
Offline mikewb
Speedometer
« on: May 28, 2007, 05:21:13 pm »
speedo dont work. replaced gauge and lines but still dont work. Whats the part on the transmission that it goes to and is that the problem?
Re: Speedometer
« Reply #1 on: May 28, 2007, 06:29:08 pm »
does the cable turn? Is it 2 or 4wd?
Offline mikewb
Re: Speedometer
« Reply #2 on: May 31, 2007, 05:31:44 pm »
it turns . its a 2 wd at first when i hooked it up the speedometer was bouncing up and down from 0 to however fast i was goin then it just quit
Offline mikewb
Re: Speedometer
« Reply #3 on: May 31, 2007, 06:51:51 pm »
nevermind it doesnt spin anymore lol
Offline mikewb
Re: Speedometer
« Reply #4 on: June 01, 2007, 12:14:28 am »
got it workin but up till 25 it bounces within about 5 to ten miles an hour after 25 its normal anyone know why?
Offline ccz145a
Re: Speedometer
« Reply #5 on: June 01, 2007, 08:06:43 am »
A jumping speedometer is the result of three possibilities.
1.A kink in the cable. The kink may be in the inner cable, although the design of these cables tends to prevent this. Easy to check though, just pull out the inner cable being careful to keep it clean and see if there is a dogleg bend in it, if that is the case replace.
2.Cable needs lubrication, if there is no kink just lube the cable with some moly-graphite dry power as you slip it back in. Sometimes people lube it with transmission fluid, if someone did that to yours, lube again with transmission fluid since using graphite now would just gum it up.
3.If nothing else works there is too sharp a bend in the outer cable routing, sometimes this happens up where the the cable attaches to the speedometer head. In this case try to straighten and reroute the cable with not-so-sharp bends.
One more thing, I usually work from the dash side of the cable. It is much easier to stay clean up top.
Hope this helps.
Offline mikewb
Re: Speedometer
« Reply #6 on: June 02, 2007, 08:40:22 pm »
Why would my trans fluid be coming out where the speedo line screws on ?
Offline mikewb
Re: Speedometer
« Reply #7 on: June 04, 2007, 01:14:25 pm »
Mine has no seal . is there anywhere i could go that would know the one i need
Offline 78chevy
Re: Speedometer
« Reply #8 on: June 04, 2007, 09:41:32 pm »
Go to autozone.com and look for the Vehicle Repair Guides link and follow the screens to get repair info on your truck.
