Author Topic: will 15" wheel fit a drop spindle?  (Read 6643 times)
Offline bigbubba87
« on: May 29, 2007, 10:36:27 am »
2.5" spindle drop,will a 15" wheel fit?
Offline bigblock73
  • Yeller
Re: will 15" wheel fit a drop spindle?
« Reply #1 on: May 29, 2007, 11:09:09 am »
Yes it will
3" spindles require the LCA to be trimmed slightly when running a 15.
Jeff
'73 swb 2wd
73-87.com
Offline bigbubba87
« Reply #2 on: May 29, 2007, 03:19:12 pm »
i was told by a manufature that the stock 15" wheel will not work.
i don't know what to do now?
is there a way to measure?
« Reply #3 on: May 29, 2007, 04:58:21 pm »
Who is the manufacturer?
Offline bigbubba87
« Reply #4 on: May 29, 2007, 08:16:14 pm »
chassis tech
« Reply #5 on: May 30, 2007, 10:14:01 am »
If it really is a 2.5" spindle, the 15's will fit.  You might have to clearance the brake caliper and lower control arm, but they will fit.
Offline bigblock73
  • Yeller
« Reply #6 on: May 30, 2007, 11:44:58 am »
I would not buy a Chassis Tech part, go with Western Chassis or ECE (if they carry em for our trucks)..much better parts IMO.
If you want to go 3", then go with Bell Tech...but you will have clearance issues with a 15 inch wheel.
Jeff
'73 swb 2wd
73-87.com
