Author Topic: 383 ideas...  (Read 10889 times)
Offline 75 C20
383 ideas...
« on: June 10, 2007, 06:39:01 pm »
im thinking of building a 383 stroker ;D i want something that will really move. im gonna get a 350 block out of my dads 95 chevy van. i was wondering who makes a really good 383 kit-combo for the bottom end and another one that would work good for the top end. i saw some in summit from egale awhile back i think and was lookin at top end packages from edelbrock that have heads, cam and intake. the bottom end ones from egale said about 400 ponies i think but if i could find a good 500+ :o combo and not brake the bank i would love it
im open to input on this idea
edit* it will hopefuly end up in a 72 gmc Sierra Grande 1/2 ton just like the one below - which is wut i wanna buy next ;D ;D
« Last Edit: June 12, 2007, 06:49:26 pm by 75 C20 »
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline Prong
Re: 383 ideas...
« Reply #1 on: June 10, 2007, 07:16:58 pm »
One thing to keep in mind is if you're going to build a 500hp motor, you need to consider is will the current transmission and rear end take the abuse. When I built my 383 for my truck, it has a TH350 tranny and a 10 bolt rear. At the time, I didn't have the $$ to upgrade to a TH400 and a beefier 12 bolt rear for a high end build.  So, I just went moderate and spec'd it to 350hp according to several popular 383 builds. 9.5:1 compression, fairly stout cam (about .470-480 lift IIRC) 2.02 fuelie heads. As is, it makes great power, puts a smile on your face, and will run ok on pump gas and get semi-decent mileage. Just something to think about...
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Re: 383 ideas...
« Reply #2 on: June 10, 2007, 08:46:04 pm »
I would use summit as they are very reputable. There are a lot of other companies but try getting one of these companies to back their purchases. Your best bet is to get a balanced rotating and reciprocating assembly. Have a GOOD machine shop bore and finish hone your block once you have the pistons. As far as the top end goes think about what you want it to do, you aren't going to get 500HP without a pretty radical cam and high compression ratio and aftermarket ignition system. Edelbrock sells a nice set of aluminum heads- don't overlook all of the basics too- use a standard volume oil pump unless you are going with a high capacity pan. Oil pump drive shaft with a steel sleeve, Double roller timing set and you get the idea...You want 500HP open your wallet!  ;D
Re: 383 ideas...
« Reply #3 on: June 10, 2007, 10:45:34 pm »
.......... a beefier 12 bolt rear for a high end build.....
As far as strength is concerned the 10bolt is fairly equal in strength to a 12bolt.  The 10 bolt pinion size is only 3/8" smaller, BUT the pinion is larger.
Offline 75 C20
Re: 383 ideas...
« Reply #4 on: June 10, 2007, 10:46:40 pm »
vile- i plan on opening up the wallet quit a bit on this one- its not just gonna happen reall quick but im just now starting to roll the idea around and get the ball moving if i know what i mean :)
Quote
i am not really worried about mileage because its just gonna be a weekender if that-- and i figure on running high octane gas in it
« Last Edit: June 10, 2007, 11:23:32 pm by 75 C20 »
Offline 75 C20
Re: 383 ideas...
« Reply #5 on: June 10, 2007, 11:20:27 pm »
heres is some of the bottom ends i was looking at
http://store.summitracing.com/partdetail.asp?part=ESP%2DB12010030&autoview=sku
theres this cheaper one
http://store.summitracing.com/partdetail.asp?part=ESP%2DB13004L03053&autoview=sku
 one question i have is since the block is a 95 do i have to get a crank made for a one piece or if a get a 2 piece real main seal crank will it work??
heres the top end i was thinking about
http://store.summitracing.com/partdetail.asp?part=EDL%2D2096&autoview=sku
anybody have ideas if they would work good together ?? or is there something else someone thinks i should get???
Offline joesgarage71
  • Wrench
Re: 383 ideas...
« Reply #6 on: June 11, 2007, 10:29:13 am »
 Well If you got a bunch cash burning a hole in your pocket, Get a crate engine with a warrenty,something like this from sdparts.com 502/502 or look into something from your local machine shop that you can see run and that comes with a dyno sheet.
http://www.sdparts.com/images/products/detail/12496962_detail.jpg
« Last Edit: June 11, 2007, 10:31:22 am by joesgarage71 »
Offline 75 C20
Re: 383 ideas...
« Reply #7 on: June 11, 2007, 12:36:55 pm »
Quote
hahaah- ive never had that problem.
i want to build hte engine myslef instead of just buying a crate engine if you know what i mean
Offline 123 pugsy
Re: 383 ideas...
« Reply #8 on: June 11, 2007, 02:09:05 pm »
You need a kit made for 1 piece rear main seal.
Pugsy
76 C10 LWB
TPI 350
Re: 383 ideas...
« Reply #9 on: June 11, 2007, 04:29:51 pm »
Yeah the one piece rear main crank is externally balanced. The 2 piece is internally balanced as you can tell when you look at the back of the crankshaft it has a counter balanced flange.
Definitely build your own engine, it's fun and rewarding and it's all you. the $ you sink into a crate engine you could pump into lots of extra goodies ,,,
Offline cruppert77
Re: 383 ideas...
« Reply #10 on: June 11, 2007, 10:06:41 pm »
I used this Trick Flow kit from Summit  http://store.summitracing.com/partdetail.asp?part=TFS%2DK314%2D500%2D450&autoview=sku. They advertise 500hp if you use a Victor Jr. intake and a 750 carb. I am VERY happy with it. Not good for air conditioning, or brakes for that matter, but still streetable. Had to lose the 2500 stall for a 3200. I liked it because I knew everything would work together, I'm not as experienced as some of the guys on this site. Let me know if you have any questions, I'll help as much as I can.
Offline 75 C20
Re: 383 ideas...
« Reply #11 on: June 12, 2007, 06:43:06 pm »
wellp i think hopefully by the end of next summer im gonna go ahead and buy this top end http://store.summitracing.com/partdetail.asp?part=EDL%2D2096&autoview=sku
and this bottom end http://store.summitracing.com/partdetail.asp?part=ESP%2DB13004L03053&autoview=sku
i was looking and the top end  is about good for 1500 to 6500 rmp range
would u guys run a stall on that?
u how big of a carb should i run?
think i would get 460 hp like it says with that combo??
if it does do 400+ would a 350 tranny hold up to that plus a decent shift kit so my head can hit the back window when i grab 2nd or should i look into getting a 400 or something else??
now i wish i had about 3000 saved up.... ;)
  • Wrench
Re: 383 ideas...
« Reply #12 on: June 13, 2007, 09:12:36 am »
 At least a 2500 stall
 750 CFM Carb
 I'd be sure to use a small base circle cam too.
Steve
Offline 75 C20
Re: 383 ideas...
« Reply #13 on: June 13, 2007, 08:36:28 pm »
Quote
the edelborck kit has a cam with it
