Author Topic: Right Side Brake Cable  (Read 8666 times)
Offline JJSZABO
« on: June 22, 2007, 07:28:24 am »
I replaced all the brake cables with cables from   and need to know how to anchor the cable over the rear differential - Please see the picture.
I bought the clip that was in   - but it doesn't fit.  I could spot weld the clip to the differential top but will the weld heat hurt the differential?  I would use only a couple of spot welds.
Any and all help is truely appreciated.
Jeff
Jeff
86 Chevy C-10
350, TH400
Re: Right Side Brake Cable
« Reply #1 on: June 22, 2007, 04:12:17 pm »
There's supposed to be a bracket that attaches to the top bolt on the meatball cover and has a loop on it that the cable sits in.
Offline JJSZABO
« Reply #2 on: June 22, 2007, 08:22:11 pm »
VileZambonie - Do you have a picture?
Jeff
86 Chevy C-10
350, TH400
Offline red4wd
« Reply #3 on: June 22, 2007, 09:20:16 pm »
I went and took a couple on an old housing I have...hope they help
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #4 on: July 13, 2007, 11:22:42 pm »
What year is your truck? Mine is a 79 and it has individual cables for the left and right that mount to brackets forward of the rearend. I bought them locally. The brand was Raybestos.....really nice pieces.
Offline 80stepsideguy
« Reply #5 on: July 23, 2007, 01:18:16 pm »
IS your truck a c10? My 80 has 2 rear brake cables that look like this in the pics once installed.
thanks
pat
p.s. they look pretty long to me in your pic but then again i could be wrong.
1998 Chevy 1500 S/B 2wd
« Reply #6 on: July 23, 2007, 04:25:40 pm »
The parking brake lines changed in the early 80's to run down the drivers side as his is pictured.
