Author Topic: Radiator Hose Help!!! 82 Crew Cab 454  (Read 4492 times)
Offline xtremjeepn
« on: June 26, 2007, 07:22:25 pm »
I am rebuilding this truck from a basket case.
Dropped the radiator in the truck and went to 2 auto parts stores to get hoses. The hoses are the right length and curves but the diameter is WAY TOO small. I can stick the hose right into the radiator without even touching the opening if I am real carefull. No way it will even come close to stretching to fit.
Ideas?
Cole
Restomod Crew Cab Short box on 37"s
Re: Radiator Hose Help!!! 82 Crew Cab 454
« Reply #1 on: June 26, 2007, 07:56:45 pm »
They switched sizes of some the hoses at one point in time I think.  Where did the radiator come out of.  Ask to look at an earlier model hose.
Offline red4wd
« Reply #2 on: June 26, 2007, 08:00:02 pm »
I would look at one from an earlier model and see if it is larger.  If they have them in stock then it wouldn't cost anything to look.
« Reply #3 on: June 26, 2007, 08:01:39 pm »
Try crossing the oem numbers...
 Radiator Hose, Upper 14029236 $26.98 Notes
 Radiator Hose, Lower 362300 $32.86
Offline xtremjeepn
« Reply #4 on: June 26, 2007, 08:24:27 pm »
I will try that.
I have two radiators. One from my 74 with 454 which is about 4" narrower than the one in the 82. So obviously I wanted to use the larger radiator.
Cole
