Author Topic: Edelbrock Pro Flo EFI  (Read 15825 times)
Offline eventhorizon66
« on: July 08, 2007, 06:32:13 pm »
I am about to swap the POS 305 out for a Goodwrench 350 in my 85 C10.  I shooting for max fuel economy and have a little extra dough to play with EFI.  I have already decided against TBI due to the poor cost to benefit ratio (a well tuned Q-Jet will get about the same mileage as TBI).  I was wondering if anyone has tried an Edelbrock Pro Flo system?  I am looking at the 3503 system.
Also does anyone think a short bed with 700R4, 3.08s, 29" tire, free exhaust, no emmissions, and a light foot can touch 20mpg?  No...stop laughing...I have an uncle who gets that in a heavier late model extended-cab Chevy (he doesn't even drive like grandpa moses).
'85 C10 SWB 350 700R4 TKO600
Re: Edelbrock Pro Flo EFI
« Reply #1 on: July 08, 2007, 11:05:54 pm »
The TBI can get 20mpg, my truck has gotten almost 23mpg (22.8) on all the trips I go on.  I drive it everday also.  I can recheck, but last time I figured the mileage (I do alot of short driving) it was getting about 18mpg.
For the money, the TBI is a better option as the Pro-Flo is going to have a poor cost to benefit ratio unless you are talking about anything other than stock.
« Reply #2 on: July 09, 2007, 10:47:57 pm »
Thanks for the reply, I will have to investigate TBI further.  So far the only turn key TBI systems I know of are from Turbo City.  Do you know of any others?
Offline Stewart G Griffin
« Reply #4 on: July 10, 2007, 10:22:40 am »
i think you can get at least 20mpg.  I also have the crate 350 and i think that's what i'm getting;  I will officially measure it soon.
I also agree that EFI is not cost effective unless you're doing alot of driving.  I.e., 600+miles per week.  But i do not nessesarily feel a Q-jet will equal EFI in fuel efficiency.  I think EFI can get up to 10% improvement in MPG, not to mention the other benefits of more power and better driveablilty.
I feel the following contribute greatly to fuel economy (more than 2%):
Engine size----CID matches vehicle?
a)compression; higher is better for mpg
b)camshaft;  conservative low end torque is better for mpg
Induction----carb vs. EFI
Tires
Aerodynamics
Weight
Gearing ,including overdrives and lockup converters.
Exhaust---big time
How you drive----makes the biggest difference.
I feel the following contribute to a smaller extent (2% or less)
electric fan(s)
Is the duct to the air filter hooked up?----so the engine gets cold air instead of hot.
Type of oil----synthetic vs. regular.  Also the weight makes a difference.
« Last Edit: July 10, 2007, 10:26:20 am by Stewart G Griffin »
« Reply #5 on: July 10, 2007, 01:31:14 pm »
Thanks for all the help.  Leaning towards TBI now, even though it doesn't have the cool factor that the Edelbrock system has.  dang boring practicality!!!
« Reply #6 on: July 10, 2007, 03:46:21 pm »
High compression is not a good idea if you are wanting good gas mileage, it will force you to use higher octane = more money per gallon.
You also wouldn't want to pair hight compression with an RV cam
Oil type won't have even a 2% impact on gas mileage.
« Reply #7 on: July 11, 2007, 10:41:32 am »
1)Good point about the higher compression.  Premium is anywhere from .30 to .40 cents higher than regular around here, and that probably wouldn't be cost-effective.  If gas prices were lower, maybe higher compression would be a good avenue to take.
2)Why won't an RV cam work w/ high compression?
3)i would like expand a little with the aerodyamics point above;  I feel that lowering and chopping the top would produce substantial gains (possibly up to 10%) improvement in MPG.  But i'm not sure i want to do that to my truck.  At least not now.
« Reply #8 on: July 11, 2007, 12:31:05 pm »
Most RV cams are designed with a max of about 9.5:1 compression, generally it is 8-9.5:1 range
Chopping the top off a truck with a flat front end isn't going to give any advantages that will be noticable.
If you want to make a big impact, do like GM did and drop the curb weight.
Offline Toolmaster
« Reply #9 on: July 11, 2007, 12:56:07 pm »
Chevy trucks were built for hauling not speed. They have the aerodynamics of a BRICK ! (heavy & Square)  If your looking for Aerodynamics and gas mileage, you might try looking for a ricer.  It will be a quicker process.
Offline ccz145a
« Reply #10 on: July 11, 2007, 01:22:37 pm »
Nice point, toolmaster. :D
« Reply #11 on: July 11, 2007, 02:42:28 pm »
I dare you to say that to my trucks face  ;)
Offline red4wd
« Reply #12 on: July 11, 2007, 02:45:53 pm »
Have you considered propane?  It is cheaper and cleaner burning.  You could even do a dual fuel system that would allow you to run on either propane or gasoline.  With propane having a boiling point -45 degrees you wouldn't have any issues with having cool air fuel mixture either.
« Reply #13 on: July 11, 2007, 08:26:00 pm »
Tell me more about propane.
« Reply #14 on: July 11, 2007, 10:57:59 pm »
