Author Topic: My 1980 Chevy C10 Restomod  (Read 675724 times)
Offline 80stepsideguy
Re: My 1980 Chevy C10 Restomod
« Reply #510 on: February 10, 2011, 03:41:56 am »
This weekend i`ll send some pics  here.Right now just no motivation to do much.I may end up throwing some things out like the wiper arm assembly i got from you and a few other things.The wiper arms i`m gonna have chromed.The rest that bolts under the cowl is getting chucked along with the worn out window regulators..
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline bowtieman82
« Reply #511 on: February 10, 2011, 01:18:24 pm »
i love your truck. im fixing a 82 4x4. i want to look as good as yours. got ant tips on body work.
« Reply #512 on: February 11, 2011, 02:42:20 am »
Use a paintstick to do the body filler sanding.I usually put the filler on, board file it with 36 grit, use black guide coat over the 36 grit marks, take a paint stick and 80 grit and fold it so its flat on the stick, take your index fingers and thumbsand pinch each end making sure the paint stick is flat an sand in a X pattern. Sand till you see the black gone.If you see any low spots, reskim the areas.And then once you get to where its nice.Then take polyester glazing putty.I personally prefer USC icing. Put it on over the filler, then do the paint stick remedy again with 80 grit, once you got it sanded some where you cut the top layer of the putty, switch to 100-120 but before that take spray bomb black , give the putty a light/medium coat, then do the sanding and you should be good till the putty is smooth and the black guide coat is all but gone...Thats how i did the truck..
thanks
pat
p.s. thank you for the compliment it took me a long time to get it this far and i gotta redo the drivers door i chipped the paint and im not happy till its redone which should be soon.
Offline bowtieman82
« Reply #513 on: February 11, 2011, 09:32:51 pm »
how about getting dents out on the bottom of the door i cant get hammer down in there to pound them out, and i dont want fill it with bondo to much.
Offline Grim 82
« Reply #514 on: February 11, 2011, 09:43:49 pm »
Uni-spotter stud welder and a slide hammer, but don't hijack the man's build thread. Start your own post in the body forum.
« Reply #515 on: February 13, 2011, 07:35:20 am »
Just got 3 pics of the truck,
here they are as of right now.
« Reply #516 on: February 14, 2011, 10:47:49 am »
Giggity! Lookin goooooood!
Offline slammed79
  • Thou shalt not drive stock
« Reply #517 on: February 14, 2011, 11:33:52 am »
Gorgeous!  Simply gorgeous
Praise the lowered
Offline JRConnieK10
« Reply #518 on: February 14, 2011, 11:43:20 am »
Gee thanks Pat, now I drooled all over my keyboard. SO BEAUTIFUL!!
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
« Reply #519 on: February 14, 2011, 05:09:20 pm »
VERY NICE!
Offline Slooby
« Reply #520 on: February 14, 2011, 06:11:47 pm »
Very nice, I like the color too.
« Reply #521 on: February 15, 2011, 11:38:24 am »
Thanks guys for the compliments.
I`m working on the headlight bezels now, i got them painted but gonna put a couple more coats on them and then install them.Then i think i`m gonna start plumbing the motor and tranny.
thanks
Pat
p.s. headlight bezels are on and done, looks alot better now:
« Last Edit: February 18, 2011, 04:50:34 pm by 80stepsideguy »
Offline 1983stepside
« Reply #522 on: March 03, 2011, 09:40:12 am »
i just love this truck the more i see it the more i want to get mine done, good work and cant wait to see more 8)
« Reply #523 on: March 03, 2011, 12:44:59 pm »
Thanks for the compliment
i`m going to be putting the glass in the doors, and the rear back window in within the next month.I`m going to be purchasing the window weatherstriping and the door glass weatherstriping soon.Also dynomat the inside of the doors.And i`m getting the driveshaft made.And also plumb the motor and tranny, i`m hoping by the time i leave for ocean city maryland in may for my car show trip i go to every year i`ll have more pics and and hoping all thats left will be the interior and wiring..
thanks
Pat
Offline hotrod24
« Reply #524 on: March 04, 2011, 07:25:37 pm »
WoW pat that thing is a beast, I new when you started it was going to come out looking awesome...
« Last Edit: March 05, 2011, 12:13:02 am by hotrod24 »
1978 pontiac grand prix...
