Author Topic: Lowered suspension shocks.  (Read 5916 times)
Offline cjtimp
« on: July 17, 2007, 06:37:58 pm »
I am getting ready to lower my truck 2/4. I have a 82 C10, SWB.  Not sure if I am going to use coils or spindles in front, but will likely use replacement springs and or shackles in rear. Will I need to replace the rear shocks with a 4" drop? Or can i keep the factory replacements?
Offline low3+3
Re: Lowered suspension shocks.
« Reply #1 on: July 17, 2007, 07:41:29 pm »
in my experience its always better to use drop shocks. I've gotten lots of drop shocks from djm and never had a complaint
« Reply #2 on: July 17, 2007, 10:30:52 pm »
If you are running shock extenders in the rear you can use the factory shocks, for the front I highly recommend dropped shocks. (they are actually shocks that have a different compression/extension length to match the drop)
Offline cjtimp
« Reply #3 on: July 18, 2007, 06:39:26 pm »
Thanks !! I like the lowered look, just wanna keep the ride as "factory" as possible. Thanks again.
Offline Uno99
« Reply #4 on: July 26, 2007, 06:17:09 pm »
I recommend drop shocks as well.  If you under there doing the work you should replace them anyways.
1981 GMC High Sierra SBO 350 LT Headers 2.5" Tru Duals, H-pipe, Flowmaster SUPER 44 Mufflers 2000 TCI Stall PICS http://www.cardomain.com/ride/2410355
Offline 1badgmc
« Reply #5 on: August 17, 2007, 01:34:16 pm »
If you use spindles, you won't need the drop shocks. Spindles don't actually change the suspension and shock travel. If you use coils, you should get a set.
Jason
1988 Chevrolet Crew Cab Dually
1991 GMC Sportside
1998 Chevrolet Suburban
