Author Topic: aftermarket tach  (Read 9301 times)
Offline gold84gmc
aftermarket tach
« on: August 06, 2007, 01:33:18 pm »
hi, i have an 84 gmc 2500 2wd with the 5.7L 4bbl engine...im trying to hook up an aftermarket tach. it says to hook up one of the wires of the tach to the distributor, on the connection marked "tach". but i looked and there is already a white wire plugged into there but the truck dosnt have a factory tach. so can i unplug that wire and plug in the one for the tach? or will it screw up something or what? and does anyone know what that white wire is for or where it goes? thanks.
92 buick century custom 3.3L
Offline gold84gmc
Re: aftermarket tach
« Reply #1 on: August 07, 2007, 11:10:07 am »
anyone have any ideas? or should i just try it.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: August 07, 2007, 11:24:42 am »
I am assuming you have an HEI distributor.  Your white wire is not in the "Tach" slot, it is in the "coil" slot.  The green wire from the tach goes to the terminal labeled "tach" on distr.cap.
If you ever replaced the coil inside the distr. cap, you'll see what I'm speaking of. If memory serves me, you will see a red wire and a white wire from the coil.  The only wire you see plugged into the bottom side of that area is the red wire w/ white clip.  That is the ignition wire.
« Last Edit: August 07, 2007, 11:36:30 am by SgtDel »
Offline DirtyLittleSecret
« Reply #3 on: August 07, 2007, 11:28:39 am »
And if the wires are pink/purple with a light lemon twist and sugared rim? (just jokin')
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
Offline 123 pugsy
« Reply #4 on: August 07, 2007, 11:36:24 am »
Pull it out and try it. ;)
Pugsy
76 C10 LWB
TPI 350
« Reply #5 on: August 07, 2007, 02:51:45 pm »
Do you have Vacuum advance or HEI with ESC?
Offline gold84gmc
« Reply #6 on: August 07, 2007, 02:54:47 pm »
here is some pics of what im talkin about. the white wire that plugs in to the "tach" slot
Offline gold84gmc
« Reply #7 on: August 07, 2007, 02:55:44 pm »
as far as i know its vacum, because its a 1984
« Reply #8 on: August 07, 2007, 08:36:05 pm »
Is there a 4 wire plug connected to the distributor?
Offline gold84gmc
« Reply #9 on: August 07, 2007, 09:23:18 pm »
yea there is one big plug, not sure if its 3 or 4 wires though..i'd have to look.
« Reply #10 on: August 08, 2007, 10:00:29 am »
Then you need that wire. Just splice into it.
Offline gold84gmc
« Reply #11 on: August 08, 2007, 02:56:37 pm »
alright, thanks
