Author Topic: Any Aftermarket Hood Locks?  (Read 8574 times)
Offline DirtyLittleSecret
« on: August 12, 2007, 10:42:33 pm »
As the title implies...does anyone know of any aftermarket hood locks for those of us without?  Or is it best to just hit the U-Pull-Its (would the OEM bolt in)?
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
Re: Any Aftermarket Hood Locks?
« Reply #1 on: May 11, 2008, 07:10:14 pm »
Nobody? :-\
« Reply #2 on: May 11, 2008, 08:27:21 pm »
 ??? huh?
Offline Swims350
    • Cars and trucks
« Reply #3 on: May 11, 2008, 08:53:14 pm »
oem hood lock?
only ones I ever seen were the mr. gaskets hood locks like a hood pin, but have like a round pop machine style lock and key.
www.cardomain.com/id/benwa454
Offline bigkountry
« Reply #4 on: May 12, 2008, 03:59:44 pm »
Pins or twist locks (mostly used on glass hoods in racing) will be your only choice I think.
Try Jegs or summit
Offline ccz145a
« Reply #5 on: May 12, 2008, 04:06:07 pm »
I've seen logging chain and master lock, too. ;D
« Reply #6 on: May 31, 2008, 08:32:52 pm »
Took a look at Jegs and Summit, but nothing found as of yet.  Yes, a chain would work, but is not really the look I'm going for...
Its sad that there are alot of things no longer available for these classics.
« Reply #7 on: June 01, 2008, 09:58:41 am »
I did up a guys hunting truck 78 K20 for him one time. I welded two pad lock hasps to either side of the tail gate, and hood to fenders. Then bolted two from the cap rear door to the gate. still could have broken the windows to get in, but thats what he wanted. We bolted a steel tool box into the bed with locks on it too. Then I painted the whole truck OD green.
« Reply #8 on: June 02, 2008, 01:10:54 pm »
An OEM from the 76-80 will work.  (I think it was 76..)
