My truck has the tank switch valve, but only 1 tank, how do I make gauge work?
Topic: My truck has the tank switch valve, but only 1 tank, how do I make gauge work? (Read 6016 times)
1976Scottsdale
August 14, 2007, 02:39:25 pm »
My truck had dual tanks at one point and now has only 1 tank, but it still has the switch valve. It is the one with a lot of wires running to it. I am wanting to make my fuel gauge work, what wires do I need to move around and what colors are they?
Re: My truck has the tank switch valve, but only 1 tank, how do I make gauge work?
August 14, 2007, 04:10:46 pm »
All you need to do is flip the switch. Are you saying if you eliminate the switch?
⌠ŻŻŻŻŻ' [☼===☼]
stevens
August 14, 2007, 06:10:39 pm »
The sending unit is on top of the gas gage so just run it straight to the one gas tank
1976Scottsdale
August 14, 2007, 11:10:30 pm »
My truck has had parts swapped here and there, so it no longer has the tank switch in the cab, nor the wiring for it I think, but the wiring and parts are still on the frame. I am just wanting to find out what color the wire is for the fuel gauge, the last one I did was pink or red, so I can run a jumper wire to the tank from the splitter valve and make the gauge work.
DirtyLittleSecret
August 14, 2007, 11:31:27 pm »
OR
you could invest in another gas tank/switch!
My wife calls it her insurance plan...another tank to tap!
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
1976Scottsdale
August 15, 2007, 07:35:09 am »
My wiring harness in the cab is not original to my particular truck and does not have provisions for the tank switch.
DirtyLittleSecret
August 16, 2007, 03:45:56 pm »
Ah, now I got it. Sorry I dont have a quick/easy answer for you
Is there anyway you could do a Painless Wiring fuel wiring kit (dedicated/closed)? That's what I'd check into at this point.
