Author Topic: Swapping late model steering wheel into '79 3/4 ton?  (Read 13581 times)
Offline lt1kicker
« on: August 27, 2007, 03:16:35 pm »
When I first got my truck I posted about wondering if the four-spoke steering wheels from a later model (88-94) full-size would fit in a '79 Scottsdale.  I was told it would.
I bought a nice wheel out of a '93 or '94 1500 this past weekend and took it home.  To my dismay it appears that the holes do not line up on the older steering column (just looking at the center of the steering wheel).  Did I get the wrong wheel, or would it have to be retrofitted?  Any help/guidance would be appreciated.
Aj
1979 Chevrolet Scottdale 4x4, 350, 180k
1994 Caprice 9C1, LT1, G80
1995 Caprice 9C1, LT1, FOM9C1
www.fallenofficermemorial9c1.org
Re: Swapping late model steering wheel into '79 3/4 ton?
« Reply #1 on: August 27, 2007, 09:56:41 pm »
What holes are you talking about? The steering shaft is splined and has a nut holding it on.
« Reply #2 on: August 28, 2007, 05:16:31 am »
It should slide right on there. I am 99% sure the center hole is the same diamiter and spline.
« Reply #3 on: August 28, 2007, 10:49:18 am »
They used the same basic Saginaw column for every GM vehicle from 1969 up to 1994 (non-airbag version.)  They used them on Jeeps too....  The wheel should fit on there fine.
Offline lt1kicker
« Reply #4 on: August 28, 2007, 11:44:08 am »
Ok, I was confused on what all held the wheel in place.  I look at it again and it appears just the castle nut is what actually holds it in place.  Can't wait to get this done, the wheel I got is pretty nice.
Aj
« Reply #5 on: August 28, 2007, 09:14:19 pm »
The key switch in my 86 is from an 88 wrangler. ;D
Offline lt1kicker
« Reply #6 on: August 29, 2007, 04:59:09 pm »
Put my wheel on in no time last night.  If I had all the right tools laid out it would have taken a fraction of the half-hour it took me ;D
It looks a lot better.
Aj
Offline ccz145a
« Reply #7 on: August 29, 2007, 06:07:01 pm »
Please post a picture to let us know what this looks like. I might want to do this swap, too. My wheel is all gummy and excreting a weird sticky substance.
« Reply #8 on: August 30, 2007, 06:53:21 pm »
Laquer thinner will clean that stuff right off. Castrol Super Clean also works pretty good too, but seams to leave a film of its own behind.
Offline okuma
« Reply #9 on: September 01, 2007, 01:56:05 pm »
here are some pix of my custom leather wrapped steering wheel.
Offline lt1kicker
« Reply #10 on: September 05, 2007, 04:39:47 pm »
Here's the wheel.  I haven't even cleaned it up yet, but I'm very happy with the improvement.  Next project is replacing all or most of the dash, including cover, gauges, etc.
Aj
Offline elegy_c10
« Reply #11 on: September 05, 2007, 06:02:54 pm »
im not sure...but my truck has an entire steering column out of an 85. its an 78
Offline 1973c20
« Reply #12 on: September 05, 2007, 06:29:17 pm »
My '73 C20 has the same gummy steering wheel problem  :-\ I have an '89 Wrangler that has a GM steering column in it and oddly enough the steering wheel on that also gets sticky when its humid  ???
Offline Dave Kay
« Reply #13 on: September 30, 2007, 01:11:47 pm »
Okuma, where'd you get that spiffy looking steering wheel? WAY sharp!
Offline okuma
« Reply #14 on: October 01, 2007, 11:30:32 am »
Edited- all for sale items go in the Classified boards.
« Last Edit: October 01, 2007, 01:06:28 pm by Captkaos »
