Author Topic: What kind of mods for a camper?  (Read 14508 times)
Offline 81Cheyenne
« on: September 01, 2007, 02:46:37 pm »
Hi all,
I have an '81 LWB C10 with a stock 305 4bbl, TH 350, standard rear axle and heavy duty rear springs. What mods would you suggest to make it more suitable for a camper?  I would prefer to go with a slide-in but may also wind up with a pull-behind.
thanks,
-Shawn
Re: What kind of mods for a camper?
« Reply #1 on: September 01, 2007, 03:35:04 pm »
Hi all,
thanks,
-Shawn
Slide in with a 1/2 ton is scary.  The newer ones are lighter but stay within the trucks limit.  Good shocks and a sway bar up front definately helps.  Older heavier ones make the truck feel like it is going to tip over.  If you go with a pull behind, make sure if you get one with trailer brakes put a unit on your truck.
Offline 79apache
« Reply #2 on: September 02, 2007, 02:37:45 am »
Gotta agree, Slide-in might be a bit heavy. Trick out your topper(lights, blow-up mattress, etc.) and add one of those tents that hooks to the back of it. OR, tow a small trailer.
Guess you could always beef up your suspension but if you are going to go to that trouble, might as well getcha a beefer 3/4 or 1T 4 wheel drive Chevy.
Course then your fuel mileage goes down the hole and you will never come see your brother in WV.
LOL!!
Offline 81Cheyenne
« Reply #3 on: September 02, 2007, 07:26:51 am »
Got the sway bar.  I'll look into the shocks too.  What about the springs?  Anybody know what the "Heavy Duty" springs are rated for?  Will springs from a 3/4 ton fit?
79Apache:As far as I can tell, the Interstate between here and WV is a 2 way road Bro! I'll tie up the dogs and keep the light on for you.
« Last Edit: September 02, 2007, 08:17:54 am by 81Cheyenne »
« Reply #4 on: September 02, 2007, 08:29:08 am »
Count your leaf spring stack.  I have a healthy stack on my on Suburban parts truck that was added to by a spring place that beefed it up for towing (I have a receipt).  You should have a sticker on your door with that info on GVW/GVCW
« Reply #5 on: September 02, 2007, 03:06:48 pm »
Use an air helper spring
Offline 81Cheyenne
« Reply #6 on: September 02, 2007, 03:44:12 pm »
Where can I find out more about that?  I don't know what they look like or where to buy them.  Anything online that has a pic?
« Reply #7 on: September 02, 2007, 06:16:25 pm »
I got a set of helper leafs from the back end of my 1/2 ton GMC.  I think they came from JC Whitney.
« Reply #8 on: September 02, 2007, 06:53:17 pm »
Lotsa places sell them, Summit, just google it. http://www.stengelbros.com/AirLiftApplicationGuideGM.htm#ChevTrk
Offline 81Cheyenne
« Reply #9 on: September 03, 2007, 08:44:49 am »
Ok, here's what I found:
The sticker on the door says    GVWR                GAWR   FRT                     GAWR   RR
                                          5600/2540          2950 / 1339                     3406 / 1545
I have counted a total of 5 leaves on the springs, the 4 top leaves are the same thickness and the bottom leaf is quite a bit thicker.  The bottom leaf is a bit shorter also.  They measure 51" from bolt to bolt and have what appear to be shackles that lower the frame about 4".  Looks like the shackles are a stock part.
I like the ride of what I have but would like to be able to safely handle the weight of the camper.  I checked out the link (thanks Vile) and I like the looks of the air helpers.  Would these work better for this than going to heavier springs?
« Reply #10 on: September 03, 2007, 10:50:46 am »
I've put them on trucks carrying a 5th wheel with lots of extra cargo and never had a problem. Personally I would probably go that route also.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #11 on: September 03, 2007, 08:00:13 pm »
Now that you have ideas on suspension, don't forget your transmission and coolant.  If your truck wan't designed for pulling, you cannot overlook the idea of getting a 4 core radiator.   And, you MUSt get a transission cooler that mounts in front of the radiator.
Check out what i did for my 79 big 10.
Offline 81Cheyenne
« Reply #12 on: September 11, 2007, 07:55:51 am »
Pretty cool site.
Is a TH 350 tranny sufficient for my needs?  I have an extra one that I can tinker with.  Would I be better off rebuilding and modding this one or just looking for a TH 400?
Offline DirtyLittleSecret
« Reply #13 on: September 11, 2007, 10:41:51 am »
The TH350 is a VERY capable transmission, and some might even say its better than a TH400.  Tranny cooler would be a MUST on my list.
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
Offline 81Cheyenne
« Reply #14 on: September 12, 2007, 08:33:57 am »
I'm also curious about a 700R4.  Is this a viable alternative? I like the idea of the overdrive for fuel mileage and a lower 1st gear.  Sounds like it might do well with a torqy motor.  Would it hold up as well as a TH350 when hauling or pulling?
