Author Topic: Headlight Help!  (Read 5911 times)
Offline 83HighSierra
Headlight Help!
« on: September 03, 2007, 01:19:24 am »
Ive been looking in magazines and on the internet and i can not find headlights that are not sealed beams.
 Do they make headlights that just the bulbs are interchangeable not the whole assembly? Thanks in advance
Offline okuma
Re: Headlight Help!
« Reply #1 on: September 03, 2007, 06:44:54 am »
Re: Headlight Help!
« Reply #2 on: September 03, 2007, 05:14:13 pm »
Basicallyi just want to buy these type of headlights, do these have changable bulbs or are they sealed beams? if not how can i make them interchangable?
Here are the headlights...
http://www. competitor.com/icatalog/cc/0073.asp
« Last Edit: September 03, 2007, 05:41:39 pm by 83HighSierra »
Offline okuma
Re: Headlight Help!
« Reply #3 on: September 03, 2007, 05:47:50 pm »
THESE ARE INTERCHANGABLE HEADLIGHTS!
Re: Headlight Help!
« Reply #4 on: September 03, 2007, 06:17:58 pm »
i know the ones on ebay were, but they dont say if they are for dual headlight setups, and i wanted to know if the ones i saw in   were, and if you had to buy a certain harness.
« Last Edit: September 03, 2007, 06:39:40 pm by 83HighSierra »
Re: Headlight Help!
« Reply #5 on: September 03, 2007, 07:10:59 pm »
83 they are the same as the OEM headlight but utilize a bulb insert like an H9004. If the pigtail is different it will come with one.
Re: Headlight Help!
« Reply #6 on: September 03, 2007, 08:13:33 pm »
So if i were to get the ones from   i could put for example, silverstar bulbs in it and if it were to go out just change the bulb not the whole assembly?
Offline okuma
Re: Headlight Help!
« Reply #7 on: September 03, 2007, 08:22:48 pm »
YOU DO NOT NEED DIFFERENT PIGTAILS ALL YOU WILL NEED IS TO BUY THE H4 MODEL HEAD LIGHTS.      H4 REPLACEMENT BULB WILL FIT EXACTLY TO ORIGINAL PIGTAILS......  ;)
Offline okuma
Re: Headlight Help!
« Reply #8 on: September 03, 2007, 08:24:37 pm »
I JUST NOTICED THE ONE ON EBAY .......ALREADY HAVE THE H4 BULB INCLUDED!!!!  NOT A THING TO WORRY ABOUT NOW. ;D
Re: Headlight Help!
« Reply #9 on: September 03, 2007, 08:41:05 pm »
okay i get it know. im looking at the ones on ebay and they dont say if they are for the upper or lower headlight. im considering them tho. im also looking at the ones in  . those are the h4 model headlight also right? i just want to make sure before im stuck with the sealed beam headlights.
