Author Topic: Manual swap  (Read 6664 times)
Offline 87GMC2WD
Manual swap
« on: September 04, 2007, 10:55:19 am »
hey guys, i have an 87 GMC 1500 2wd with  a 350 TBI and a 700R. Has anyone swapped the 700r out for like a 5 speed stick? im 17 and would love the truck to be a stick. just wondering if its worth it
Re: Manual swap
« Reply #1 on: September 04, 2007, 04:23:38 pm »
I wouldn't do it unless you're putting in a 6 speed. It can be done though
Re: Manual swap
« Reply #2 on: September 04, 2007, 05:36:06 pm »
You will need to source everything from a manual equipped truck.  OR I think Keilser has setups now that are hydrualic and pretty much complete.
Offline 87GMC2WD
Re: Manual swap
« Reply #3 on: September 05, 2007, 03:33:35 pm »
how much do those run for? and a 6 speed would be better than a 5?
Re: Manual swap
« Reply #4 on: September 05, 2007, 03:43:53 pm »
Offline 87GMC2WD
Re: Manual swap
« Reply #5 on: September 11, 2007, 01:55:41 pm »
anyplace that sells a kit with a transmission? or is there any good kinda of trannys that would fit that i could get from a junk yard? and who prefers the 5 speed over the 6?
Offline eventhorizon66
Re: Manual swap
« Reply #6 on: September 11, 2007, 08:45:20 pm »
I've already decided that if I have the money, when my my 700r4 finally bites the dust, I'm converting to a Tremec TKO 5-speed (the one w/3.27 1st).  I would like the T56's better if they had four underdriven gears, one direct, and one overdrive.  Who needs double overdrive?  You could get a Richmond six, but that's big bucks.  And close ratios boxes aren't approprate for trucks with torquey engines IMO.  The TKO has a GVWR of 5500 lbs (based on last generation rating) vs. max 4000 lbs for the T56 (depends on version).  On top of that the TKOs offer more shifter mounting options.
'85 C10 SWB 350 700R4 TKO600
Re: Manual swap
« Reply #7 on: September 11, 2007, 11:18:14 pm »
Keilser that I listed above sells the whole kit with the trans....  You could get a T56 from an F-body, but I would avoid the factory GM 5 speeds..  They won't hold up to abuse
Offline 1973c20
Re: Manual swap
« Reply #8 on: September 12, 2007, 12:11:10 pm »
I'd suggest going with the Peugeot BA-10 5-speed, it is very reliable  ::) and has a nice rally-esque gear whine  :P, which is why i have it in my Jeep  :D....haha just messin, it wouldn't probly fit nor would it stand up to the abuse, I sometimes wonder why I still have it....
Offline 87GMC2WD
Re: Manual swap
« Reply #9 on: September 12, 2007, 01:43:24 pm »
is said on that website that captkoas gave me that it was for a 55-57 chevy truck. idk if i just miss read it or not but.
Offline 1badgmc
Re: Manual swap
« Reply #10 on: September 12, 2007, 02:31:45 pm »
In my '88 dually, my dad had the TH400 swapped out for a 5-speed a few years ago.
Jason
1988 Chevrolet Crew Cab Dually
1991 GMC Sportside
1998 Chevrolet Suburban
