Author Topic: instrument bezel  (Read 4085 times)
Offline 83HighSierra
instrument bezel
« on: September 09, 2007, 06:05:53 pm »
This weekend i was going to fix my instrument lights because they are not coming on. So i replaced the headlamp switch and they still didnt work. so i decided to take out the guages to see if i could figure what was wrong. Well while i was taking out the speedo gauge they flickered on. The video link below should show yall what happens. Does anyone know what the problem is??
http://video.yahoo.com/video/play?vid=1099982
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
Re: instrument bezel
« Reply #1 on: September 09, 2007, 07:00:22 pm »
Seems like a short to me. The wire only makes contact (ground or power) when the cable pulls against it. I would say check all connections near the speedo.
« Reply #2 on: September 09, 2007, 08:07:18 pm »
well this is my first project so i dont really know what to look for. Also how do you disconect teh speedo from the cable its connected to so that you can get the guage out?
« Reply #3 on: September 09, 2007, 08:44:39 pm »
It's not a short it's an open. An open circuit related to you moving the gauges in and out is either bad pin tension at the connection or a faulty printed circuit. Remove the entire gauge assembly. There is a spring clip at the back of the speedo cable, simply press down and pull tha gauges toward you.
« Reply #4 on: September 16, 2007, 08:09:42 pm »
i took the gauge assembly out and found out that the rectangular connector wasnt fully pushed in and whenever i pulled on the speedo teh connecting wire pressed it in. Thank you guys for the help
