Performance
upgrade to 350?
Topic: upgrade to 350? (Read 17258 times)
83HighSierra
upgrade to 350?
September 09, 2007, 10:31:42 pm »
Im just starting a project and im pretty sure it has a 305 in it. my question is should i put performance parts on the 305 or get a rebuilt 350. I plan on this truck being a daily driver but i still want a little punch to it, so what do you guys suggest?
Re: upgrade to 350?
September 10, 2007, 08:35:22 am »
If you can get your hands on a 350 build that instead
Re: upgrade to 350?
September 10, 2007, 09:14:06 am »
I agree, rebuild a 350 and swap them out.
83HighSierra
Re: upgrade to 350?
September 23, 2007, 10:05:13 pm »
Well i live in a apartment complex, so i couldnt pull it here. and nobody i know would be able to keep it at there house. so it looks like im stuck with the 305 for right now. What order do you suggest that i upgrade it? Thanks in advance
FlatBlack77
Cheap Fast Reliable - Pick 2
Re: upgrade to 350?
September 24, 2007, 03:12:17 pm »
If you want to upgrade the 305, try to stick with things that you can switch over to a 350 should you ever decide to. Such as exhaust, carb, maybe intake manifold, ignition, ect.
83HighSierra
Re: upgrade to 350?
September 26, 2007, 09:12:57 pm »
so what is the best manifold, carb, and other transferable parts?
Re: upgrade to 350?
September 27, 2007, 11:52:27 am »
That would be too generic of a question and subject to opinion. Example: I hate carbs, so none of them are the best, I like EFI. If I had to pick a carb I would always go with a Q-jet which is what it probably already has. Being in a complex where you are going to be under scrutiny, will make somethings difficult. Pulling and intake off for example.
We need specifics on what you hope to accomplish, how much are you planning on spending? Is this you daily driver? Etc...
83HighSierra
Re: upgrade to 350?
September 27, 2007, 10:38:55 pm »
Well as of right now its not a daily driver but as soon as i get the ac fixed it will be. i dont want to turn it into a dragster just something that has alot of punch to it and is loud. About my spending limit, im only 17 so maybe a couple hundred every week, but whatever upgrades yall suggest are the best i could save up for it.
Re: upgrade to 350?
September 28, 2007, 09:00:13 am »
If you just got it I personally would start with the important stuff. Brakes, shocks, hoses, tune-up. Most people start with exhaust, what kind in on there now? Do you plan to put headers on it? The intake is something you can possibly do yourself in a day. Pick one that has a range of about 1500-5500rpms. Edelbrock is what I typically buy.
Keep in mind you aren't going to make alot of power gains with these since it is going on an older engine.
83HighSierra
Re: upgrade to 350?
September 28, 2007, 01:12:26 pm »
It has dual exhaust but it some cheap off brand kind. I plan to put headers on it one point, which one do you suggest? Did yoiu mean that no matter what i put on it it wont get much power gain. is there anything in particular that i should get?
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
Re: upgrade to 350?
September 28, 2007, 10:19:32 pm »
If your truck feels kind of sluggish to your taste, you can always drop the rear end gear ratio to a lower gear (higher numerically). She'll jump off the line quicker and feel like a jump in horsepower--that is until you get up to interstate driving speeds.
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
thomas
Re: upgrade to 350?
October 21, 2007, 11:18:25 am »
i have a 305 too. i did a complete rebuild with new cam, heads, intake, headers, custom chip, but i kept the TBI for now. all of those will sawp to a 350, too.
treny
Re: upgrade to 350?
November 16, 2007, 06:33:58 am »
I did it (305-350) makes a big difference stock , Do it Bud you wont regret it.
Hii There , Stating another project , an 83 c10 2wd .Frame etc is all good and have to replace dash pad and seat , some body work and Paint Prob flat blk wth a clear cote to seal it.Ill keep in touch with updates ..Bruce
85MudMonster
Re: upgrade to 350?
November 16, 2007, 11:11:30 pm »
I know Chevy 350's are common and easily avaliable, they practically grow on trees, but I am not the kind of guy to do what eveyone else does. I don't want a BBC, I'd like to stick to a SBC, but what other feasable options are there besides the 350, that will make about 300hp, and like 350-400ft/lbs of torque and still be a good daily driver engine....BTW, sorry to tread jack, but I felt this was along the same lines as this...
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Re: upgrade to 350?
November 17, 2007, 01:37:41 am »
your most cost effective and practical method will be the 350. If you want unique then custom build your own engine. I built my friend from an Olds 350 block a 362. I used 425 pitons and bore it .068 over to fit. It's unique but still more work with less results. If you wanna stick to sbc and don't want a 350 then build a 400 or a stroker or destroke a 400
Performance
upgrade to 350?
