Author Topic: Changing over to a TBI?  (Read 13325 times)
Offline 76CrewCab4x4
« on: September 14, 2007, 12:38:29 am »
I have a 76 Crew Cab 4x4 with 350 c.i Engine, Edelbrock 600 carb., Th 350 Transmission, NP203 Transfer Case. Fuel consumption is around 10 mpg at it's best.  I've owned the truck since 1988 and am in the process of improving it's looks and performance.  I've thought about changing over to a TBI system.  I owned a 88 Chevy C10 with a 305 c.i. and a TBI which performed phenomenal on fuel and power.  I have at my disposal the ECM and wiring (everything that under the dash, from an 88 Suburban with a 350 c.i.  I know I need a lot more items but, would having this ECM and wiring be advantageous in obtaining?  Has anyone done a conversion over to a TBI and is happy with the results?  If I can increase my fuel economy by just 2 mpg, that's a 20% increase!  Like going from 20 mpg to 24 mpg. What have be the mpg results from the conversion?   Any and all input would be appreciated.
Tom
Re: Changing over to a TBI?
« Reply #1 on: September 14, 2007, 10:09:05 am »
You will reap all of the benefits of EFI. Easy starting, better fuel economy and better stoichiometry. It's not that hard to do. Swap the intake and TBI. Install the EFI distributor, the sensors, you'll need an O2 bung, the fuel pump, harness ECM etc and you'll have to cut a hole in the firewall. A good investment if you are gonna keep the truck!
« Reply #2 on: September 14, 2007, 10:39:58 am »
Thanks!  I do plan on keeping the truck.  Kept it this long, might as well keep it untill one of us can no longer be useful.
« Reply #3 on: September 14, 2007, 10:56:56 am »
I too believe it is well worth the effort especially if you have all the donor pieces at your fingertips.  The 87-up TBI heads are the new centerbolt version, it my be necessary to modify the intake to fit on an older style head.
I am in the process of converting my 78 Jimmy to TPI.
Offline friendlytruck
  • altitude !^^^!
« Reply #4 on: April 14, 2009, 06:43:41 pm »
hi discovered a wrecked 1995 1/2ton silverado with EFI Wood this fit my GMC, just a complet swap work EFI parts.
Ap riy= [Cha d’fhuaireadh facal Beurla mar Scottish Gaelic]
Life is short gory is eternel
Offline oldwhity
« Reply #5 on: April 14, 2009, 09:08:48 pm »
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #6 on: April 14, 2009, 09:11:31 pm »
i was thinking the same thing oldwhity  ;D
stoi·chi·om·e·try [stòykee ómmətree]
n
1.  branch of chemistry: the branch of chemistry concerned with measuring the proportions of elements that combine when chemical reactions take place
2.  measure: a measure of the relative proportions of the chemical elements that take part in a chemical reaction
[Mid-19th century. Coined from Greek stoikheion “element” on the model of German Stöchiometrie .]
Microsoft® Encarta® Reference Library 2004. © 1993-2003 Microsoft Corporation. All rights reserved.
« Reply #7 on: April 14, 2009, 09:11:57 pm »
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #8 on: April 14, 2009, 09:13:55 pm »
Where's that thread about naming trucks....I think I just found the name of my next truck.  :D
Offline oldwhity
« Reply #9 on: April 14, 2009, 09:17:37 pm »
That's too funny! :D So truck run gooder. Me get it! lol
Rob G.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #10 on: April 14, 2009, 09:34:51 pm »
« Reply #11 on: April 14, 2009, 09:43:47 pm »
LOL did you see the date on that post? A stoichiometric air fuel ratio is ideal.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #12 on: April 14, 2009, 09:47:15 pm »
sept. 07, wow, didn't realize that.
Offline TexasRed
« Reply #13 on: April 14, 2009, 09:54:04 pm »
It also means longer engine life due to less fuel washdown of the cylinders.
  • altitude !^^^!
« Reply #14 on: April 15, 2009, 01:19:41 am »
I mean i discovered a wrecked 1995 1/2ton silverado with EFI and my 1986 350 stock motor has a carburettor on it but i Wood like Fuel Injection on it so wood the parts fit my GMC, just a bolt in job no modifications to any parts.
« Last Edit: April 15, 2009, 10:26:31 am by Captkaos »
