Author Topic: Grant steering wheel  (Read 5792 times)
Offline Mr. G
« on: September 18, 2007, 02:52:05 pm »
Hi all. I am trying to install a Grant steering wheel on my 73 C10. Problem is when I tighten the nut the wheel is really hard to turn. As it turns out I am supposes to install a "ring" on the main shaft before the Grant hub goes on and it doesn't come in the kit and it doesn't exist on the factory wheel. Anyone ever come up with a solution for this?
Re: Grant steering wheel
« Reply #1 on: September 18, 2007, 03:07:22 pm »
Do you have the correct hub for your column? If the hub is bottoming out and not preloading the upper column bearing it will cause it to bind. Take a few pix of what you've got going on exactly and make sure you have the right hub
Offline FlatBlack77
« Reply #2 on: September 18, 2007, 03:20:02 pm »
Just out of curiosity, what wheel did ya get?
I am thinkin about a Grant Challenger 4 spoke or the crome chain wheel
Offline Big78Chevy
  • I HAVE 4 KIDS.......MY TRUCK IS ONE OF THEM!
« Reply #3 on: September 18, 2007, 06:06:06 pm »
The washer is just an 1/8 thick (just installed one yesterday) just get a proper washer to fit the shaft snuggly (inside diam.) and it will work fine. P.S. just a tip .....when you come to installing the horn button sand off or sratch some of the paint(on the wheel if you have a painted one) for the opposite side of the fiberboard (metal side) that comes in the install kit, so the horn will work. LOL..... I had scratched my rearend for 15min. as to why it wasn't working!  lol lol   My only excuse , It was Monday.
AS I DROVE THROUGH THE VALLEY OF DEATH,I HEARD A VOICE SAY TO ME "WHAT ARE YOU DOING HERE THIS IS FORD COUNTRY"! I YELLED OUT "I FEAR NO FORDS"!
Offline JJSZABO
« Reply #4 on: September 19, 2007, 07:52:46 am »
Lets see some pics of the install - Like to see what it looks like.
Jeff
86 Chevy C-10
350, TH400
Offline Mr. G
« Reply #5 on: September 22, 2007, 12:58:40 pm »
Thanks big78chevy. I could not find a washer that worked so I made one. Works like a charm. There is nothing like old school powersteering and a small wheel, so easy to park.
