Author Topic: Mutt Project  (Read 750098 times)
Offline LTZ C20
Re: Mutt Project
« Reply #315 on: January 26, 2016, 10:06:24 pm »
I just saw that you have a Rotary lift in your garage! That's a bunch of crap! Lol. The pump motor looks exactly like a bunch we have at the shop. Let me guess, yellow swing out extendable arms. Are your towers parallel to the lifted vehicle or do you have one of those ones that have the towers angled out towards the opposite side rear corners of the vehicle when it's on the lift? We have a few of those angled tower ones and I don't like them, I like the parallel tower lifts better.
LTZ Cheyenne C20
Re: Mutt Project
« Reply #316 on: January 26, 2016, 10:53:33 pm »
10,000lb asymmetric, curious why you wouldn't favor this design?
Offline LTZ C20
Re: Mutt Project
« Reply #317 on: January 27, 2016, 12:31:49 am »
The ones we have its a pain in the neck to get the car in the right spot to pick it up, and not everything fits on it. Trucks with long beds fit if they are regular cab but long crews almost don't fit. But the steel plate that's bolted to the ground to indicate the proper position when pulling in is missing, bolts are sheared off from years of use. All the parallel racks can pick up any length car or truck and we have 1 in the back shop that's rated for like 60,000 lbs I think or something. Maybe it's 50K. Anyway, everything is like 3 times thicker on that rack than the others. Plus with the asymmetric lift, the arms don't always swing their full arc depending on how short or long that car is. Either the fronts won't reach their lift points because the you have to pull in to far so that backs will reach their lift points or vise versa. I've had cars that just plain won't fit on it, that's not to common tho.
LTZ Cheyenne C20
Offline fitz
Re: Mutt Project
« Reply #318 on: January 27, 2016, 03:58:27 am »
I had a Challenger 10k asymmetrical lift. It was great, it did everything that I needed it to do.
Offline LTZ C20
Re: Mutt Project
« Reply #319 on: January 27, 2016, 09:36:41 am »
We use all rotary lifts here with the exception of one or two that are "GM Dealer Service Equipment".
LTZ Cheyenne C20
Re: Mutt Project
« Reply #320 on: January 27, 2016, 06:59:44 pm »
When I installed my lift I set it in accordance with my buddies crew cab long bed so it is positioned where I can lift pretty much any truck, car, ATV, lawn mower, you name it. I wouldn't want any other kind. Last year I turned it into a bar when I had a party with about 100 people here. It was easy to raise the bar that day ;) Very versatile lift
Offline LTZ C20
Re: Mutt Project
« Reply #321 on: January 27, 2016, 09:10:27 pm »
Well maybe that's the issue we have then. It was just installed and on to the next one, when it should have been setup for larger vehicles to be more centered on the vehicles. It's not a problem we constantly have, it just seems like every time I have a slight hiccup. But granted I rarely use it.
We have about 30 racks, 7 are drive on, 2 are asymmetric and the rest on parallel.
Does yours have the flip up steel mounts to pick up a vehicle or does yours have the collars with feet that have rubber mounts and that you screw down or up to adjust for the proper height to pick?
LTZ Cheyenne C20
Re: Mutt Project
« Reply #322 on: January 28, 2016, 08:50:03 am »
Stack on collars. I don't like the flip up or screw jack designs
Offline LTZ C20
Re: Mutt Project
« Reply #323 on: January 28, 2016, 09:11:59 am »
Yea, most of ours are the flip up design, and few of them are the screw type, the big 50-60K lift uses massive screw type. The stack on collars are good.
LTZ Cheyenne C20
Re: Mutt Project
« Reply #324 on: January 30, 2016, 05:56:32 pm »
Didn't get as much as I planned to done today but still made some progress. I was like should I shouldn't I should I shouldn't I with this grille. It's a GM original that was basically mint and since I am not having any chrome or stainless on this unit I said the heck with it. Cleaned, sanded & primed the bezels, grille, grille emblem (not sure if I will use this emblem or the lumi-logo but I'm going to do it anyway), wiper arms, drip rails and gas caps. Tomorrow I'll get the base black base coat on everything and then I need to mask and paint the orange areas to see how I like it.
« Last Edit: September 06, 2017, 04:02:19 pm by VileZambonie »
Re: Mutt Project
« Reply #325 on: July 03, 2016, 10:23:08 am »
Making some progress....these pics look red
« Last Edit: September 06, 2017, 04:10:06 pm by VileZambonie »
Offline Militiaman55
  • 74 K10 Cheyenne
Re: Mutt Project
« Reply #326 on: July 04, 2016, 01:12:30 am »
Sweeeeeeeeeeeeet........
Offline RossCravens
Re: Mutt Project
« Reply #327 on: July 05, 2016, 09:04:07 am »
Awesome build!  The truck looks awesome!
'86 GMC C10 SWB--454
"There is no replacement for displacement"
'06 Chevy 2500 LBZ
Gig 'Em Aggies
Offline winky
Re: Mutt Project
« Reply #328 on: July 13, 2016, 08:26:21 pm »
looks awesome, what paint are you using?
Offline RAD77C10
Re: Mutt Project
« Reply #329 on: August 07, 2016, 01:11:10 am »
Is your orange paint, a two stage paint?
