Author Topic: Popping noise up front  (Read 8436 times)
Offline Injected
« on: October 09, 2007, 02:44:47 pm »
I've got a 1985 K10 Silverado with a 4" Rancho lift and 33's. I have the infamous "popping" noise coming from the front drivers side when I turn the wheels. I've checked and replaced the drag link ends and rod ends but it's still there. I checked the frame around steering box for the crack everyone talks about but I don't see anything out of the ordinary.
Just wondering if those who have had this happen found the crack only when they removed the steering box? I've had a couple of shops look at it too and they can't find the source either.
Anybody know or have any ideas?
Thanks,
Greg
Offline ccz145a
Re: Popping noise up front
« Reply #1 on: October 09, 2007, 02:49:49 pm »
I had my upper control arm shims fall out once. It made a noise I could describe as a "pop pop pop". Are you sure all of your shims are in place?
Offline KojaK 79k10
« Reply #2 on: October 10, 2007, 07:30:41 pm »
you could check your balljoints, wheel bearings and axle joints. Does this happen when you are going around a corner or just turning period. you could have some metal to metal contact somewhere.
77 Chevy swb "race truck"
*SOLD* 79' k10 Silverado SWB "Kojak"
truck is gone but not forgotten, worst thing I ever did was sell this truck and I regret it everyday.
Offline okuma
« Reply #3 on: October 10, 2007, 08:29:33 pm »
CHECK THE BEARING THAT IS ON THE STEERING SHAFT UNDER THE MASTER CYLINDER. there is a sealed bearing carrier where the 2 shafts connect. maybe there is no bearings on it anymore.
Offline red4wd
« Reply #4 on: October 10, 2007, 08:36:38 pm »
You might want to check your steering box...I have seen a couple instances where the frame cracks around the bolts that hold the steering box on...for what its worth
« Reply #5 on: October 11, 2007, 09:01:53 am »
I would check the axle joints before anything else. They are the most common thing to make a popping noise.
 You probably already know but if you don't, don't try to check your upper control arm shims as you don't have them.
Offline ccz145a
« Reply #6 on: October 11, 2007, 01:40:12 pm »
duh, k10... right. I need to read a little closer.
cp
« Reply #7 on: October 11, 2007, 10:06:25 pm »
 ;D
Offline Injected
« Reply #8 on: October 17, 2007, 04:36:52 pm »
Thanks for all the suggestions guys!
Ball joints and axle joints have been checked and are good, and there are no cracks in the frame - unless they are behind the box out of sight - I'm going to take it off sometime in the near future and check the frame behind it.
I'll check the steering shaft too, I checked the rag joint but that was it.
Thanks again guys, I'll let you know what I find.
Greg
Offline Injected
« Reply #9 on: October 22, 2007, 10:37:22 am »
Found it!
When the previous owner put the 4" Rancho lift kit in they let one of the axle Ubolts rub up against the spring pack, I corrected that and got the spring plate straight with no contact on the spring pack from the Ubolts, and now the noise is gone.
I love it when a fix involves no $$$!
