Author Topic: "Cold Weather Proofing"  (Read 8166 times)
Offline DirtyLittleSecret
« on: October 09, 2007, 05:05:21 pm »
Figured a thread for preparing these trucks for cold weather was in order since we are looking to have a cold winter...
Things to do/can do to help maintain our babies in the cold:
Check antifreeze/full flush with PROPER amount of antifreeze!  Dont forget to flush with the heater on!
Add an electric cab heater
Drain fluids/check for water in drivetrain/swap to synthetics
Add a block heater
Add a transmission "blanket"
Add a radiator "blanket"
Drive it!
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
Re: "Cold Weather Proofing"
« Reply #1 on: October 09, 2007, 08:32:05 pm »
I put a bottle of dry gas in every tank full of fuel.
Offline KojaK 79k10
« Reply #2 on: October 09, 2007, 09:13:40 pm »
#1 thing= CHECK YOUR BATTERY! In cold weather, if you don't have a battery with enough cold cranking amps you will NOT crank that thing over. also check your choke operation, too much or little choke clearance can really hurt startup. also check tire pressure as well as brake system.
77 Chevy swb "race truck"
*SOLD* 79' k10 Silverado SWB "Kojak"
truck is gone but not forgotten, worst thing I ever did was sell this truck and I regret it everyday.
Offline 123 pugsy
« Reply #3 on: October 10, 2007, 08:29:00 am »
Its a Chevy Truck. Check the antifreeze and drive that sucker. That's all I've ever done. ;D
Pugsy
76 C10 LWB
TPI 350
« Reply #4 on: October 10, 2007, 09:32:55 am »
Put a HOT chick in your truck and you won't be worried about COLD anything :D
Offline 81Cheyenne
« Reply #5 on: October 10, 2007, 09:58:43 am »
Kinda hard on the wallet though!  ;D
Offline Bitzer!
  • Smiles per gallon
« Reply #6 on: October 10, 2007, 03:31:02 pm »
Kinda hard on the wallet though!  The only thing thats hard?
1979 GMC CrewCab  C20 1t
Offline Toolmaster
« Reply #7 on: October 10, 2007, 04:29:37 pm »
Move south !  No No No Just send the trucks south !!  HEHEHEHHE
The temp hasent gotten under 70 that I know of this year.
Kinda hard to get ready for hunting seasion around hear, Something about
sitting in a tree sweating & swatting bugs.
Send Rain also ! Frogs are farting dust !!
