Author Topic: demensions  (Read 6651 times)
Offline 1978 3/4
demensions
« on: October 11, 2007, 10:31:56 am »
I'm trying to get my 78 3/4 back to stock  height,whats the factory
dimensions of rear lift block? anyone
Re: demensions
« Reply #1 on: October 11, 2007, 12:57:56 pm »
Rear lift block?  There shouldn't be a factory lift block just springs on perch
Offline 1978 3/4
Re: demensions
« Reply #2 on: October 11, 2007, 08:34:35 pm »
Really ,are you sure? if so the previous owner must have installed?
let me be more clear,6 months ago i removed blocks (rear) they may have been 1"3/4 thick ,i installed 3" blocks ,Really Ruined the ride!
I threw away the first blocks(dumb) so thats why I cant find  stock
ones! they never Had them
thanks for info
Re: demensions
« Reply #3 on: October 11, 2007, 10:18:01 pm »
Have a machine shop mill you up a pair. Can't be that many $ as its just a block with a hole in one side and a nub on the other, or a hole right through it and bolt it to the springs with the center bolt.
Re: demensions
« Reply #4 on: October 12, 2007, 10:06:15 am »
If all you changed were the blocks in the rear I am confused on how it ruined the ride, it is only a 1.25" difference.  You can remove the one you have and have someone cut it down to the previous size.  BUT they never came with blocks from the factory.
Re: demensions
« Reply #5 on: October 12, 2007, 11:40:42 am »
you can get another set of blocks from Autozone with U-bolts for less than $50 bucks
