Author Topic: A few more pieces added to my 355  (Read 12218 times)
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« on: October 30, 2007, 09:51:55 pm »
Just purchased the Russell Pro Flex carb line and hose. Had to be black and silver to match the rest of the engine. Bought the small CHEVROLET air cleaner but it's gotta go--too small.
Just thought I'd share some slow progress.
Next is a GMPP aluminum water pump (reverse flow since I'm running a serp belt system from a 91 Z-28.). Thinking of chroming the o.e
pulleys since the front of the engine has alot of black. Gotta add a spacer for the carb to clear the booster nipple on the back of the intake etc etc etc.
Thanx for looking.
Offline werewolfx13
Re: A few more pieces added to my 355
« Reply #1 on: October 30, 2007, 09:54:39 pm »
thats purdy  ;D
Chris
'83 Chevy c10 Silverado SWB
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #2 on: October 30, 2007, 10:00:52 pm »
THANX!
I'm taking donations  ;D
Dollars, twenty's, anything helps.
Not homeless-just need help!
LOL
« Reply #3 on: October 30, 2007, 10:18:37 pm »
Engine looks nice. Hope yer painting that firewall though  :o
Offline SUX2BU99
« Reply #4 on: November 01, 2007, 12:57:31 pm »
Very sharp. I like those valve covers. What did you pay for those? The local speed shop has some as well, but I'm always looking for a good deal.
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #5 on: November 01, 2007, 04:55:52 pm »
I got them 6-8 months ago from JEGS. I think they were $115.00 but they may have gone up.
Offline 85MudMonster
« Reply #6 on: November 08, 2007, 02:41:05 am »
WOW!! That is so beautiful! Makes me want one like that sooo bad!
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #7 on: November 08, 2007, 07:21:07 am »
Is that sarcasm? LOL.
I'm just really anal about making this truck look as nice as I can afford.
I woulda loved to put a 572/620 horse motor in it but that's way out of my budget. I should have the GMPP aluminum water pump this week. Then it's starter, alt, p/s pump and distributor, tensioner and belt. STILL waiting to sell my other (new) headers and get the Chevelle style (ceramic).
« Reply #8 on: November 08, 2007, 08:25:45 pm »
no not sarcasm. it really is awesome. I love how clean and simple it is, it's the oposite of my 305 which is ugly and busy. Is it a crate engine or you put it together piece by piece?
Dan
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #9 on: November 10, 2007, 12:12:35 pm »
Thanks for the compliment. I built it to look clean and simple. I hate the clutterd look and wanted to stick with the black, gray, silver look. Once the serpentine system is installed, it won't be as uncluttered but it'll still be simple and clean looking.
No, it's not a crate. I chose every piece of that engine personally and spent 4 saturdays porting and polishing the heads. There is alot of machine work in it. There's more info on it elsewhere on the site if you're interested. The 3 "old time" machinists who did some of the machine work figure it'll make an easy 400 horses. As for all the time and money in the heads--it NORMALLY doesn't pay to put that much into cast iron heads, but, these are 041X heads (very rare) and they were given to me. Otherwise it would've been more cost effective to just buy aluminum. I used to work for an auto parts store that had a machine shop otherwise this particular engine would not be done yet and i'd have paid A LOT more for it.
Offline baddogg79
« Reply #10 on: November 11, 2007, 07:27:54 am »
Beautiful set up :o
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #11 on: November 15, 2007, 09:42:22 pm »
Thanx again for the compliments !
Just FYI; for those who run a Holley carb and have a clearance issue (under the back bowl) for the 90 degree fitting to run you brake booster hose........
obviously you can run the ole 1 inch spacer available from almost any parts store, but, using that as a solution can actually raise your rpm range--slightly reducing low end torque.
I had a buddy that works at a machine shop mill a spacer down to 1/2 inch thick. It clears the fitting and looks a little better (in my opinion).
« Reply #12 on: November 15, 2007, 11:16:04 pm »
I thought the longer the intake and more backpressure the more torque you make (obviously with-in reason though, not to much of either)?
Dan
« Reply #13 on: November 16, 2007, 12:57:18 am »
That's why many manufacturers have gone to variable intake geomtery. Lower RPM torque is increased with the longer runners howver the shorter ruuners help promote high RPM runners
Offline 78ScottsdaleK20
« Reply #14 on: November 16, 2007, 03:14:52 pm »
Good looking set up! I agree with Vile on painting that firewall. Do everything you can to make that engine bay look good! I did a motor swap and put a sweet setup in my 78 K20 and didnt do anything to the engine bay and regret it now, talk about a diamond in the rough! It is a pain keeping everything clean. Call me crazy, but I even wax my valve covers and air cleaner...its a sickness.
BTW, what makes a motor a 355 ci? Is it because its bored .30 or .40 over...?
78 Scottsdale K20
350 SM465 NP205
4" w 35's
