Author Topic: Heater Hose Firewall Seal  (Read 15398 times)
Offline JJSZABO
« on: October 31, 2007, 10:10:00 am »
What seals the firewall at the heater hoses?
It's hard to see in the picture but I have no seal.
The heater hose holes are oblonged, not round so round grommets will not work.
Thanks for looking.
Jeff
86 Chevy C-10
350, TH400
Offline ccz145a
Re: Heater Hose Firewall Seal
« Reply #1 on: October 31, 2007, 10:43:57 am »
Pretty sure there is a glob of asphalt type putty formed around the pipes on the inside. The same stuff used at the a/c housing openings around the accumulator on trucks equipped with that. Don't know where you get it, though. I used plumbers putty, but do not like the look of it. It's white and when touched with greasy fingers looks bad.
Maybe someone else knows more...
Offline JJSZABO
« Reply #2 on: October 31, 2007, 11:41:32 am »
Maybe use some black RTV sealant?
Jeff
86 Chevy C-10
350, TH400
« Reply #3 on: October 31, 2007, 06:22:50 pm »
Offline loudnlow87
« Reply #4 on: October 31, 2007, 08:14:23 pm »
asphalt stuff will not work. at the body shop we use this stuff called dum-dum. thats just what its called. any autobody/paint supply, maybe even some parts stores, should have it.
stock really sucks
Offline JJSZABO
« Reply #5 on: October 31, 2007, 08:39:24 pm »
Thanks Guys ;D
Jeff
86 Chevy C-10
350, TH400
« Reply #6 on: October 31, 2007, 08:40:36 pm »
Butyl tape. its what they used to use to put windshields in with. Some people call it dum dum.
Offline loudnlow87
« Reply #7 on: October 31, 2007, 09:42:51 pm »
its not exactly the same stuff. butyl tape is MUCH stickier and harder to work with.
stock really sucks
« Reply #8 on: November 01, 2007, 05:00:14 am »
Butyl tape is dumdum you can get it in round or flat.
« Reply #9 on: November 01, 2007, 06:22:08 am »
Hardware or lumber company's tend to sell the flat stuff more common as it is used for metal roofing.
