Author Topic: how many quarts of oil?  (Read 43625 times)
Offline ssgoodman
« on: November 12, 2007, 10:29:08 pm »
anyone know how many quarts of oil a stock 1976 400 engine holds?  i changed the oil saturday before work, put 5 quarts in and when i checked it it said it was way over full.  it drained for about 10 minutes and it was done draining when i went back under it.  put on a fram oil filter and filled it up and now there is brand new oil on the dipstick but quite a bit over full with only 5 gallons.  i know my old 6.2 diesel took more then 5 quarts.
also does anyone know of any easy ways to get alittle extra power out of the engine?  could i remove some of the aircleaner or put in a bigger aircleaner?  previous owner put in new plugs and wires about 2 months before i bought it.  i cut the mufflers off it yesterday and got some glasspacks i plan to turn backwards for it but looking for some other tips or tricks.  this is the first gas v8 that i have owned.
thanks
Sutton
« Last Edit: November 13, 2007, 11:18:53 am by Captkaos »
Offline ccz145a
Re: Recent purchase questions
« Reply #1 on: November 12, 2007, 11:14:11 pm »
Most of them hold 4qts plus whatever fits in the filter. If you had a small filter, then 5 would have been too much.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: November 12, 2007, 11:16:32 pm »
Sutton
welcome.  You may wanna start a new thread versus hijacking a thread--but i see the correlation "new purchase".  But w/ a new filter, 5 should do it.  Start out with 4 but dont check the oil before you run it a  little to get the filter nice and full. Then check it.
As far as getting a little more power, the best thing to do is ensure it is in tune.  Put a timing light on it.  Make sure the carbs are adjusted correctly. A bigger cleaner won't amount to anything noticeable, unless what you have on there is smaller than stock. Ensure the cats aren't clogged, if you have them.
« Last Edit: November 12, 2007, 11:22:36 pm by SgtDel »
Re: how many quarts of oil?
« Reply #3 on: November 13, 2007, 01:24:59 pm »
it drained for about 10 minutes and it was done draining when i went back under it.  put on a fram oil filter and filled it up and now there is brand new oil on the dipstick but quite a bit over full with only 5 gallons.  thanks
Sutton
You put in 5 Gallons?! it only takes 5 quarts with the filter change. Make sure you run the engine and check it on level ground 30 seconds after you shut it off.
Offline ssgoodman
« Reply #4 on: November 13, 2007, 07:01:39 pm »
i meant quarts... ::)
Offline bigblock73
  • Yeller
« Reply #5 on: November 15, 2007, 05:45:56 am »
I have always put in 4 1/2 quarts in all my SBC powered vehicles..checked out fine every time.
Jeff
'73 swb 2wd
73-87.com
Offline 85MudMonster
« Reply #6 on: November 15, 2007, 06:27:17 am »
pretty sure it should be right at 4.5 qts.
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
« Reply #7 on: November 15, 2007, 01:15:40 pm »
All the trucks I have ever worked on or owned took 5 quarts.
Offline 75 C20
« Reply #8 on: November 15, 2007, 09:44:13 pm »
always threw 5 qts in mine
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline Dragon
« Reply #9 on: November 16, 2007, 01:59:55 pm »
5 qrts have been the standard refill capacity of a SBC for years. Now that does change depending on the size of the filter used, and weither or not a Radiator/ & or an externally mounted Oil Cooler is also used, and you have a leak in the system....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
