Author Topic: power steering leak  (Read 3711 times)
Offline txtj79
  • 1980 Chevy C-10 SWB
power steering leak
« on: November 18, 2007, 08:16:11 pm »
My 1980 C-10 had a bad power steering leak.  I replaced the pump and the leak stopped.  However, I've noticed a small amount of fluid leaking out of the top of the power steering box where the steering column inserts into the box.  Is there a seal or something in there that I need to replace?  Or, do I need a new power steering box?
Thanks,
T.J.
Re: power steering leak
« Reply #1 on: November 18, 2007, 10:11:01 pm »
That's the worm gear seal. Unless you know how to set worm bearing preload and properly adjust the lash after you replace all the seals you might be better off with a reman unit.
