Author Topic: Trans crossmember and tail shaft location  (Read 3884 times)
Offline gmiles
« on: November 23, 2007, 01:32:28 pm »
There are two holes in the trans crossmember where the mount goes. The trans (TH400) mount had one bolt in the center that was broken. Which hole do I use. I know engineers designed offset either at the engine or rear end to get rid of the harmonics/balance caused by a long rotating driveshaft. BUT, which hole does the trans mount go into (driver's side or passenger side)? The bottom of the frame rails are about 29" apart and neither hole is centered. The two holes are about 1 1/2" apart.
Thanks.
Re: Trans crossmember and tail shaft location
« Reply #1 on: November 23, 2007, 01:39:44 pm »
I think you might have the wrong mount. It should be in the center.
Offline gmiles
« Reply #2 on: November 23, 2007, 02:25:54 pm »
Yup. Wrong mount. I just picked up a new one and it has the two holes that match the cross member. What would I do without this board............... :'(
