Author Topic: vinyl dye  (Read 5182 times)
Offline cruppert77
vinyl dye
« on: November 24, 2007, 09:05:30 am »
so, I'm fixen to redo my headliner. some of the trim pieces that hold up my liner are plastic, and some are metal. Will vinyl dye stick to the metal parts? Or should I try to match the color with regular spray paint?
Thanks
Offline scpscpscp
Re: vinyl dye
« Reply #1 on: November 24, 2007, 09:18:01 am »
I do not think the vinyl dye will adhere to the metal. I think you are right at matching the die with paint.  I will say that this information is dated as I have not tried this for a long time. Steve.
Re: vinyl dye
« Reply #2 on: November 24, 2007, 10:13:29 am »
Use SEM or now duplicolor makes a vinyl spray paint too that works REALLY good.
Offline cruppert77
Re: vinyl dye
« Reply #3 on: November 24, 2007, 10:27:47 am »
I'm unclear, does that mean if I use SEM, it will stick to metal?
Offline okuma
Re: vinyl dye
« Reply #4 on: November 24, 2007, 12:02:11 pm »
SEM will stick and will make a good color change...... remember to use adhisive promotor, bull dog is good.
i color change blue door panel to sand color with SEM  worked great!
Offline Dragon
Re: vinyl dye
« Reply #5 on: November 24, 2007, 05:42:31 pm »
You can use the SEM or Dupli-Color to paint/dye the metal trim pieces as well, you would need to just scuff the pieces with a red Scotch Brite pad(found at any Paint Supply or well Stocked Auto Parts/Larger Hardware Store) to promote adhesion with the metal.
When scuffing the pieces, you don't need to remove the previous paint, just scuff it enough so that you don't see any sheen in the finish.  The original coating will act as a primer coat, so you won't need to apply one unless you scuffed through to bare metal on any part of the pieces...
Be sure to properly follow the directions of the coating you are using for proper cleaning, and prep work before spraying the coating. You will also want to use the proper clear/top coating after spraying the color coat, as the finish will easily scratch/lift with accidental contact...
The adhesion promoter should be used for coating the plastic or vinyl pieces before spraying the color coat. For the metal pieces, adhesion promoter is used to give the plastic/vinyl surface grip.
« Last Edit: November 24, 2007, 05:53:14 pm by Dragon »
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline cruppert77
Re: vinyl dye
« Reply #6 on: December 06, 2007, 09:37:28 pm »
Just finished. Looks awsome. Thanks for the help.
Offline JJSZABO
Re: vinyl dye
« Reply #7 on: December 07, 2007, 07:21:12 am »
Post some pics - I still have to do this
Jeff
86 Chevy C-10
350, TH400
