Author Topic: NP203 checking and filling oil  (Read 23085 times)
Offline copekyle
« on: November 26, 2007, 03:44:40 pm »
Ok, I'm about to install a part time kit on my NP203.  What I need to know is how to check the oil level and re-fill the oil after it's been drained on the transfer case.  I know to use 10W30 to refill, I just need to know where to fill it.  I'm new to this so I apologize if that is a stupid question.
Thanks
Kyle
Re: NP203 checking and filling oil
« Reply #1 on: November 26, 2007, 04:21:33 pm »
It's not a stupid question. You should see a fill plug on the transfercase. You fill it to the bottom of the fill plug on level ground. I'll see if I can dig up a pic.
Offline ssgoodman
« Reply #3 on: November 26, 2007, 08:54:53 pm »
is 10w30 the recommended oil for a transfer case?  i thought it was 90 weight like rear-ends.
Sutton
« Reply #4 on: November 27, 2007, 12:54:37 pm »
Not in a NP203.  You are thinking the gear driven version.
Offline copekyle
« Reply #5 on: November 27, 2007, 01:24:20 pm »
Thank you so much!!!!  That's just what I needed!
